03-30-2009, 08:24 | #1 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 696126 Status: Offline Thanks Meter: 63 | sagem my220v unlock done... COM4 [VCP0] selected module v1.60 Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EBI_IO_101207_1704 EBI_IO 101207_1704 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-static_20090330-134554.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-security_20090330-134556.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20090330-134601.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_lock-area_20090330-134626.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 80 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to bbaj For This Useful Post: |
03-30-2009, 11:36 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
05-19-2009, 08:06 | #3 (permalink) |
Freak Poster Join Date: Mar 2008 Location: INDIA Age: 34
Member: 726340 Status: Offline Sonork: 100.1624264 Thanks Meter: 86 | another sagem my 220v unlock successful via infinity COM3 [VCP0] selected module v1.65 Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 253 EBI_IH EBI_IH_170707_1253 Thhmm Dddmmmyyyy 0123456789ABCDEF Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-static_20090519-121213.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-security_20090519-121213.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20090519-121214.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_lock-area_20090519-121220.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 30 sec Remove/Install battery now ! thank u infinity team |
The Following User Says Thank You to KUMARANSUGUMAR For This Useful Post: |
05-19-2009, 08:13 | #4 (permalink) |
Member: 726340 Status: Offline Sonork: 100.1624264 Thanks Meter: 86 | another successful unlock for my 220v via inifinity COM3 [VCP0] selected module v1.65 Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 253 EBI_IH EBI_IH_170707_1253 Thhmm Dddmmmyyyy 0123456789ABCDEF Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-static_20090519-121213.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-security_20090519-121213.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20090519-121214.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_lock-area_20090519-121220.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 30 sec Remove/Install battery now ! thank u infinity team |
06-02-2009, 05:08 | #5 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 615701 Status: Offline Thanks Meter: 9 | My220V unlock successful with microbox ! READING IMEI: OK! READING EEPROM: OK! SAVING EEPROM: OK! EEP_MY220V_35573************_2009_06_02_10_50_22.M BF READING DATA: OK! PHONE ALLREADY UNLOCKED! SAGEM MY220V UNLOCK: END! After unlock you must unlock with 0000 on hand ! |
06-27-2013, 20:11 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | keyboard down: Sagem, Vodafone 1..........16 1: Gnd (RJ45 pin-8 or pin-7) 9: box Rx/phone Tx/PinFinder Rx (RJ45 pin-3) 10: box Tx/phone Rx/PinFinder Tx (RJ45 pin-2) 16: Gnd (RJ45 pin-8 or pin-7) |
Help for SAGEM my220V unlocking code | ffelix | Phone Unlocking Codes & Maps | 0 | 04-23-2008 09:35 |
Sagem my220V unlocked successfully | yassyass | Infinity-Box | 1 | 04-16-2008 19:38 |
Sagem My220v Unlock Success | jhepoy_org | FuriousGold | 1 | 04-04-2008 13:20 |
sagem my220v unlock | dindou78 | SAGEM JTAG UNLOCKER | 18 | 03-07-2008 17:53 |
