Old 06-20-2015, 18:36   #1 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 429
HTC desire D616h
plz help me infinity team we have htc desire D616h flashing error
Card found: S/N 355B:0128
Chinese Miracle II [MTK module] v 1.21
Scatter Load Ok , BaseBand : MT6592 , Project : wt98518 , Storage : EMMC
Files found : 13 , Set to Flash : 12
Ready to Flash!
Operation : Flash [ v1.21 ]
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Brom Init not done
Boot Error!
Operation Failed
Elapsed: 00:00:03
Reconnect Power/Cable!
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6592_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048601A3199D51B7
DA Stat : v4.2 on BBID : 0x8A
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A3199D51B7
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6592 , Project : wt98518 , Storage : EMMC
Setting : AFF verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000000000-0x0000000000100000
Erase : 0x0000000001D00000-0x00000000E3E00000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_wt98518.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Break! Something wrong with HW or BL (FirmWare)
Done!
Elapsed: 00:00:18
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Brom Init not done
Boot Error!
Operation Failed
Elapsed: 00:00:04
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:21
Operation : Flash Erase [ v1.21 ]
User accepted Flash Erase operation!
Wait for phone...
Phone found! [ 19 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Keep Preloader alive
Flash erase done
Done!
Elapsed: 00:00:13
Files found : 12 , Set to Flash : 11
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Erase : 0x0000000001D00000-0x00000000A9F00000
Done!
Elapsed: 00:00:19
Old 06-20-2015, 21:46   #2 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 429
any one help me we have mobile backup when we backup set is hang on logo first we backup fectory firmware and ispff with infinity but after backup we flash set with another flash file but infinity software hang on write file it file was tested first we write another phone set is ok but this time problem when set dead we earse and try again error
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:19
Old 06-21-2015, 06:56   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
By log seems hardware fault. What was phone history?
Br.
Old 06-21-2015, 14:49   #4 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 429
phone was hang on htc logo
Old 06-21-2015, 23:27   #5 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 429
any solution when first time of this phone same condtion hang on Htc logo we flash this then set is ok but now this problem
Old 06-22-2015, 05:16   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Mostly seems as FlashIC fault. What error SPFT says on flashing try? Should be "Not enough space" or similar.
Old 06-22-2015, 16:12   #7 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 429
when flash isspf file then error is here
Load File
FileVersion : MT6592
Load File Ok
======= Flash
Files set for flashing :
[ MCU ] : MT6592__HTC__HTC_Desire_616_dual_sim__htc_asia_sea _wwe__htc_v3_dug__SW_G98518A2_V019_M10_HTC_V3DUG_A SIA_MP__Android_4.2.2__20140923_130223.ispff
Wait for phone...
Phone found! [ 19 ]
Sync...
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : htc
ProdName : htc_asia_sea_wwe
ProdModel : HTC Desire 616 dual sim
Device : htc_v3_dug
AndroidVer: 4.2.2
MTKxCPU : MT6592
MTKxPRJ : SW_G98518A2_V008_M10_HTC_V3DUG_ASIA_MP
ISPFF ID : 6592 , TARGET ID : 6592
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase done
Write Flash now ...
Init Ok , Sending blocks ...
Write failed
Flash Error!
Check Cable, Battery , try again
Operation Failed
Elapsed: 00:00:19
Old 06-22-2015, 17:47   #8 (permalink)
JayDi's Avatar
Member: 462970
It fail because eMMC not allow write to it. eMMC dying.
Old 06-22-2015, 19:42   #9 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 429
it,s emmc problem???
Old 06-23-2015, 07:17   #10 (permalink)
JayDi's Avatar
Member: 462970
Exactly. If it flashed before, then come to such condition - that mean eMMC became read only. It similar dead state.
Old 06-29-2015, 04:02   #11 (permalink)
Registered User
Member: 1725884
Sonork: swimming
Thanks Meter: 293
or you can try to read bin file from working phone ant write to your phone may be dump will help you....
Old 06-29-2015, 21:31   #12 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 429
no write dump file.......
Old 06-29-2015, 21:53   #13 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 348
try without re-partition option
don't do anything with hardware just return in case and suggest client to go for service center they replace with new handset in warranty.
( have to wait for 15-20 days)
Old 06-30-2015, 06:44   #14 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,626
HI,
IF YOU HAVE STILL PROBLEM----Contact us right now to Yahoo! Messenger or SONORK,ICQ , we will look remotely, where can be the problem with your device. Our contacts You can find in our profile.
The Following User Says Thank You to sunilkumar70791 For This Useful Post:
Old 06-30-2015, 06:50   #15 (permalink)
JayDi's Avatar
Member: 462970
So sad... What to do then?
Page generated in 0.25001 seconds with 8 queries
