My-g 889 help pinout MY-G 889 |
Hello, How many pins at phone connetor ? |
I found it with pin finder. Rx=4 Tx=2 my phone was locked. But, if I try to unlock/format Infinity just like this.... COM4 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 102 sec Remove/Install battery now ! Even I hold the power button until finished, it still like that..:confused::confused: |
hello! it is second MCU pinout MCU_b. for unlock you must work with first MCU. disable founded pins in pinfnder advanced settings and repeat search |
I try to search again with pinfinder and still found pinlike before (RX=4 and tx=2) 2nd CPU as you say. How I find the first CPU?????:confused::confused::confused: |
Mr. Infinity. What 'bout with my question:confused::confused: |
hello! go to pinfinder advanced settings and uncheck pins 4, 2 repeat pinout search |
Well done, Great job Infinity:D:D |
COM3 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:3DA0:BFA3 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 100 sec Remove/Install battery now ! Please infinity help about this issue. |
You can try to make "complete" format instead of "safe" |
i try to format with safe mode: COM7 [VCP0] selected module v2.64 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 97 sec Remove/Install battery now ! then try format complete mode: ALL done but phone still restart, what should i do? |
problem solved use Rx - 3 Tx - 5 Code: module v2.64 then write IMEI Code: COM7 [VCP2] selected |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
