Old 06-12-2008, 04:32   #1 (permalink)
Member: 610418
Thanks Meter: 15
Red face My-g 889
help pinout MY-G 889
Old 06-13-2008, 14:54   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
How many pins at phone connetor ?
Old 06-14-2008, 13:35   #3 (permalink)
harun_warsanto's Avatar
Member: 718412
Thanks Meter: 5
I found it with pin finder.
Rx=4
Tx=2
my phone was locked.
But, if I try to unlock/format Infinity just like this....
COM4 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6205:8B00]...
CPU: MT6205
high speed boot enabled
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 102 sec
Remove/Install battery now !
Even I hold the power button until finished, it still like that..
Old 06-14-2008, 15:33   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
it is second MCU pinout MCU_b.
for unlock you must work with first MCU.
disable founded pins in pinfnder advanced settings and repeat search
Old 06-16-2008, 06:47   #5 (permalink)
Member: 718412
Thanks Meter: 5
hello!
Hello,
I try to search again with pinfinder and still found pinlike before (RX=4 and tx=2) 2nd CPU as you say.
How I find the first CPU?????
Old 06-16-2008, 09:32   #6 (permalink)
Member: 718412
Thanks Meter: 5
Mr. Infinity.
What 'bout with my question
Old 06-16-2008, 21:09   #7 (permalink)
Member: 148515
hello!
go to pinfinder advanced settings and uncheck pins 4, 2
repeat pinout search
Old 06-17-2008, 09:54   #8 (permalink)
Member: 718412
Thanks Meter: 5
Well done,
Great job Infinity
Old 06-27-2008, 13:40   #9 (permalink)
Member: 153875
Thanks Meter: 35
hello!
I have already gone to advanced settings and unchecked pins 4 and 2 after which I got 5 and 3 but still same result:
COM3 [VCP0] selected
19200 autodetect
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:3DA0:BFA3
Connecting, wait...
Finished, time used: 100 sec
Please infinity help about this issue.
Old 06-27-2008, 13:52   #10 (permalink)
Member: 130995
You can try to make "complete" format instead of "safe"
Old 10-27-2008, 07:28   #11 (permalink)
Member: 131174
Thanks Meter: 36
my phone restart
i try to format with safe mode:
COM7 [VCP0] selected
module v2.64
19200 autodetect
CPU: MT6205
Connecting, wait...
Finished, time used: 97 sec
then try format complete mode:
ALL done
but phone still restart, what should i do?
Old 10-27-2008, 15:56   #12 (permalink)
Member: 131174
Thanks Meter: 36
problem solved
use Rx - 3 Tx - 5
module v2.64
19200 autodetect
CPU: MT6226
chip: 0031:DAC1:E482
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: MAUI.05C.W06.16
Version: MALATA26_05C_HW
detecting structure #2...
 done
60 byte(s) read
imei: 35102000125829
connection Ok
building list...
done
items to clear: 203
warning: wrong packet cs
191 of 203 items cleared
building list...
done
1 items remains
Finished, time used: 93 sec
then write IMEI
COM7 [VCP2] selected
module v2.64
Action: imei
imei write method: mode-2
imei write channel: imei #1 for dual sim/mono CPU
new imei: 351020001258295
19200 autodetect
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
 done
60 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
 done
60 byte(s) read
verification...
verification done: 35102000125829
Finished, time used: 12 sec
The Following User Says Thank You to h3rdi For This Useful Post:
Old 10-27-2008, 17:03   #13 (permalink)
Member: 130995
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
please add MY G 889 tedyjohar Infinity-Box 1 09-29-2008 13:11
TV 889 Phone Touch Pen IPMART ipmart WebShop 0 09-06-2008 15:40
TV 889 Phone Earphone IPMART ipmart WebShop 0 09-06-2008 15:40
format my-g 889 deni cell Chinese Models & Cloned Phones 2 07-18-2008 13:34
Page generated in 0.22518 seconds with 9 queries
