08-08-2015, 14:03 | #5 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | as I know this caused by if you installed sniff / usb over network sharing software or something similar etc. so uninstall that software and reboot system or use fresh installed windows. also read information from dongle manager copy / past here maybe ease for PM/PS. wBw, Nasir Javed |
08-08-2015, 14:12 | #6 (permalink) | |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Quote:
08-08-2015, 14:36 | #7 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | use Dongle Manager And Read Card info And Follow Instruction , it's because you tried to modify or delete or replace infinity cm2 files so it's a tight security for copy paste as i know only one chance for you after this dongle will be blocked permanently . |
08-08-2015, 15:11 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, DO NOT use spy/debug/sharing software to avoid forewer-blocked Boxes/Dongles ! - Download LATEST "DongleManager" software: http://server1.infinity-box.com/down...gleManager.rar - Run DongleManager.exe - Select "Infinity-Box" or "BEST Tool" or "CDMA Tool" (depends on your Box/Dongle type) at bottom of page - Read Box/Dongle serial number (S/N) Send text from software window to [email protected] Do not send screenshot/pictures - just copy/paste text from software window to your message |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
08-08-2015, 16:28 | #10 (permalink) | |
Code: Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND Flash not supported yet! Done! Elapsed: 00:00:09 Reconnect Power/Cable! Finish at : [8/8/2015 / 4:28:16 PM] Last edited by Tanha0321; 08-08-2015 at 16:35. | |
