07-02-2008, 13:56 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | << CDMA Moto W150i Dead Recovered Successfully >> Loading file v.02... w150i_Main_TATA[1].1.2.08.B2M.bin loaded Loading file v.02... w150i_Flex_FFN_A86_0111_031[1].B2F.bin loaded Loading file v.02... w150i_LPH_A86_ASIA2_016_En_Hindi[1].B2P.bin loaded COM11 [Serial2] selected Device: Motorola-W150i Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... Connect Done Initialize... detecting chip[01]... flash: 8988C400010001:8988C400000000 flash: Intel I28F320C3B-T T 4Mb Initialize Done Set baud... 921600 Set baud Done Check parameters... flash: 8988C400010001:8988C400000000 reading [Motorola-W150i_eeprom]... warning: wrong cs at 0x003F1800, retry... read error recovered file saved: D:\Program Files\InfinityBox\QCModule\backup_Motorola-W150i_eeprom_20080702-160502.B2E.bin software version: 1.2.08. flex version: FFN_A86_0111_031 LP version: LPH_A86_ASIA2_016 hardware version: MOTOROLA_A86 ESN: 1EFD5548 Check parameters Done Check flash... Check flash Done Write... Area: Firmware flash: 8988C400010001:8988C400000000 Write: Firmware "safe mode" active Area: Flex/Customization flash: 8988C400010001:8988C400000000 Write: Flex/Customization Area: Language pack flash: 8988C400010001:8988C400000000 Write: Language pack Write Done Finished, time used: 341 sec Remove/Install battery now ! |
The Following User Says Thank You to zeel_zeel For This Useful Post: |
07-03-2008, 11:17 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
06-30-2009, 21:21 | #3 (permalink) | |
Junior Member Join Date: Jul 2006
Member: 321173 Status: Offline Thanks Meter: 0 | Quote:
sir i have not sucess told me file selection in detail thanks in advanced | |
<< Spreadtrum SC6600D5 pinout & Flash/Format success >> | zeel_zeel | USB Pinfinder | 17 | 07-20-2008 14:19 |
<< Another Spreadtrum GT S168 Repaired Successfully >> | zeel_zeel | SpiderMan | 1 | 07-10-2008 06:43 |
<< CECT C1000 Spreadtrum Repaired Successfully >> | zeel_zeel | SpiderMan | 0 | 07-07-2008 12:31 |
<< LG KP202 Unlocking Success! >> | kasamiko | Infinity-Box | 3 | 01-02-2008 16:17 |
