my infinity box not working please help,. my infinity box has just stoped working suddenly,i was unlocking huawei t201,..i have unlocked almost 100pcs,but it just stoped,...when i press power on for the phone to boot ,the phone doesnt respond,full bettery charged,..good charging connector,..i have tried different pc but still same problem,i have uninstalled and installed setup but still the proble, please any one to help me?:confused: |
pls i have a problem with my infinity box; not connect to phone here is log; ==== log opened: [6/12/2009 3:17:13 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 4C5E:0111 error: Dongle firmware[0111] is out of date (too old) ! Download latest "DongleManager" from support area and upgrade Dongle firmware ! ==== log opened: [6/12/2009 3:19:10 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 4C5E:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [6/12/2009 3:19:58 PM] ==== COM8 [VCP0] selected module v2.82 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! COM7 ready error: can't open COM6 error: can't open COM3 ==== log opened: [6/14/2009 2:03:51 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 4C5E:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [6/14/2009 2:19:16 PM] ==== COM8 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair "bad software" (mode-1) Boot ... Press and HOLD Power button now ! ==== log opened: [6/14/2009 2:27:27 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 4C5E:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [6/14/2009 3:07:12 PM] ==== COM8 [VCP0] selected module v2.82 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 20 sec Remove/Install battery now ! Imei 35044801123456 already was repaired: 6/14/2009-3:07:38 PM Continue with this imei ? ==== log: [6/14/2009 3:07:58 PM] ==== COM8 [VCP0] selected module v2.82 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 43 sec Remove/Install battery now ! Imei 35044801123456 already was repaired: 6/14/2009-3:08:47 PM Continue with this imei ? operation aborted Imei 35044801123456 already was repaired: 6/14/2009-3:08:47 PM Continue with this imei ? Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 79 sec Power off phone now ! Imei 35044801123456 already was repaired: 6/14/2009-3:12:26 PM Continue with this imei ? Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 85 sec Power off phone now ! Imei 35044801123456 already was repaired: 6/14/2009-3:14:12 PM Continue with this imei ? Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 79 sec Power off phone now ! Imei 35044801123456 already was repaired: 6/14/2009-3:15:42 PM Continue with this imei ? ==== log: [6/14/2009 3:16:38 PM] ==== COM8 [VCP0] selected module v2.82 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 57 sec Remove/Install battery now ! Imei 35044801123456 already was repaired: 6/14/2009-3:17:42 PM Continue with this imei ? ==== log: [6/14/2009 3:17:49 PM] ==== COM8 [VCP0] selected module v2.82 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 23 sec Remove/Install battery now ! Imei 35044801123456 already was repaired: 6/14/2009-3:18:18 PM Continue with this imei ? ==== log: [6/14/2009 3:20:00 PM] ==== COM8 [VCP0] selected module v2.82 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 22 sec Remove/Install battery now ! Device: Autodetect 6228-6230 NAND Imei 35044801123456 already was repaired: 6/14/2009-3:20:28 PM Continue with this imei ? Action: imei Model: Autodetect 6228-6230 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 79 sec Power off phone now ! Imei 35044801123456 already was repaired: 6/14/2009-3:22:46 PM Continue with this imei ? Action: imei Model: Autodetect 6228-6230 NAND Checking data, wait... error: can't open com port error: connection failed ! operation failed ! Finished, time used: 2 sec Power off phone now ! COM11 ready Device: Autodetect 6205-6227 NOR Imei 35044801123456 already was repaired: 6/14/2009-3:27:37 PM Continue with this imei ? ==== log: [6/14/2009 3:28:53 PM] ==== COM11 [VCP0] selected module v2.82 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase #2/1 failed Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 279 sec Remove/Install battery now ! Imei 35044801123456 already was repaired: 6/14/2009-3:33:38 PM Continue with this imei ? ==== log: [6/14/2009 3:33:52 PM] ==== COM11 [VCP0] selected module v2.82 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 9600 autodetect error: boot phase #2/1 failed Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 81 sec Remove/Install battery now ! ==== log: [6/14/2009 3:36:45 PM] ==== COM11 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair "bad software" (mode-2) Boot ... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 148 sec Remove/Install battery now ! Imei 35044801123456 already was repaired: 6/14/2009-3:35:20 PM Continue with this imei ? ==== log: [6/14/2009 3:39:52 PM] ==== COM11 [VCP0] selected module v2.82 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350448011234561 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 278 sec Remove/Install battery now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 79 sec Power off phone now ! ==== log: [6/14/2009 3:48:42 PM] ==== COM11 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 14 sec Remove/Install battery now ! ==== log opened: [6/27/2009 6:13:44 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 4C5E:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [6/27/2009 6:50:54 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 error: Dongle is not found ==== log opened: [6/27/2009 6:51:22 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 error: Dongle is not found ==== log opened: [6/27/2009 6:54:52 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 4C5E:0112 Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 10 sec Power off phone now ! ==== log opened: [6/28/2009 1:09:19 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 4C5E:0112 Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! operation failed ! Finished, time used: 79 sec Power off phone now ! ==== log: [6/28/2009 1:11:24 PM] ==== COM8 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 98 sec Remove/Install battery now ! ==== log: [6/28/2009 1:13:41 PM] ==== COM8 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 143 sec Remove/Install battery now ! ==== log: [6/28/2009 1:23:04 PM] ==== COM8 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 45 sec Remove/Install battery now ! Device: Autodetect 6228-6230 NAND ==== log: [6/28/2009 1:24:28 PM] ==== COM8 [VCP0] selected module v2.82 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: read NAND flash read mode: 01 Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! Boot Fail Finished, time used: 58 sec Remove/Install battery now ! Device: Autodetect 6205-6227 NOR ==== log: [6/28/2009 1:25:55 PM] ==== COM8 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 46 sec Remove/Install battery now ! ==== log: [6/28/2009 1:27:14 PM] ==== COM8 selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 57 sec Remove/Install battery now ! ==== log: [6/28/2009 1:28:44 PM] ==== COM8 selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 62 sec Remove/Install battery now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 460800 error: connection failed ! operation failed ! Finished, time used: 20 sec Power off phone now ! |
Download latest "DongleManager" from support area and upgrade Dongle firmware ! .....that will solve your problem |
@garus It looks like you have used wrong cable. Please, double check your cable, it mat be that you need to swap Rx/Tx wires. |
