11-10-2010, 17:15 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | my infinity dont ditecte cpu MT6226BA its supported or no? a just need to change ime of this phone !!! phone nokia 6700 conecteur: micro usb 5 pines |
11-10-2010, 18:38 | #3 (permalink) |
Member: 591880 Status: Offline Thanks Meter: 561 | BAD rx/tx in the phone. affter working with pinfinder my infinity ditect phone but : Code: COM12 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [62E6:8AFE:8AFF]... CPU: MT62E6 high speed boot On error: hardware is not supported: [000062E6:00008AFE] Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 6 sec Remove/Install battery now ! |
11-10-2010, 19:19 | #4 (permalink) |
Member: 591880 Status: Offline Thanks Meter: 561 | http://forum.gsmhosting.com/vbb/f425...-help-1000967/ http://forum.gsmhosting.com/vbb/f425...ssssse-646912/ http://forum.gsmhosting.com/vbb/f425...-m2210-491095/ http://forum.gsmhosting.com/vbb/f425...6226ba-555084/ http://forum.gsmhosting.com/vbb/f425...roblem-535274/ all this links speak about mt6226ba and its supported by infinity but phor me no chance to do any operation with this phone Code: COM12 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 00F1:5DC1:BA5E status: FF high speed boot Off boot packet size: 0400 error: bootcode load error: FFFFEAFF0000E10F10C0E3FF Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 29 sec Remove/Install battery now ! |
11-10-2010, 21:58 | #6 (permalink) |
Member: 591880 Status: Offline Thanks Meter: 561 | boot packet size "2" selected and same probleme Code: COM12 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [62E6:8AFE:8A01]... CPU: MT62E6 high speed boot On error: hardware is not supported: [000062E6:00008AFE] Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 12 sec Remove/Install battery now ! |
11-10-2010, 22:57 | #8 (permalink) |
Member: 591880 Status: Offline Thanks Meter: 561 | realy i dont anderstand what hapen with this phone .i do a same operation "read detailed information "" but a dont recive a same erreur .some times the box ditecte the cpu correctly and some time not read detailed information with old chinesse miracle 2.96 Code: COM12 [VCP0] selected module v2.96 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:5DC1:BA5E status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... error: wrong answer: C5 : wrong answer after chip id request error: no any expected answer : wrong answer after chip cfi request flash: 01227E22202200:29EA0000000000 flash: Amd PL127J D 16Mb detecting chip #01 in region #00... error: no any expected answer : wrong answer after chip id request error: no any expected answer : wrong answer after chip cfi request flash: 01227E22202200:29EA0000000000 flash: Amd PL127J D 16Mb detecting chip #02 in region #00... error: wrong answer: C5 : wrong answer after chip id request error: no any expected answer : wrong answer after chip cfi request flash: 01227E22202200:29EA0000000000 flash: Amd PL127J D 16Mb detecting chip #03 in region #00... error: wrong answer: C5 : wrong answer after chip id request error: no any expected answer : wrong answer after chip cfi request flash: 01227E22202200:29EA0000000000 flash: Amd PL127J D 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 error: no any expected answer : wrong answer after chip cfi request flash: 01227E22202200:29EA0000000000 flash: Amd PL127J D 16Mb warning: wrong data size at 0x00000000, retry... warning: wrong data size at 0x00000000, retry... warning: wrong data size at 0x00000000, retry... warning: wrong data size at 0x00000000, retry... warning: wrong data size at 0x00000000, retry... warning: wrong data size at 0x00000000, retry... warning: wrong data size at 0x00000000, retry... warning: wrong data size at 0x00000000, retry... warning: wrong data size at 0x00000000, retry... error: too many retries during read operation error: can't read required memory area total flash region size: 01000000 searching rom info... warning: wrong data size at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... error: too many retries during read operation search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 01227E22202200:29EA0000000000 error: no any expected answer : wrong answer after chip cfi request flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ........................ detect standard fat location pass #1... ........................................................ detect extended fat location pass #1... ....................................................... detect standard fat offset pass #1... warning: wrong data size at 0x00DD65FC, retry... warning: wrong data size at 0x00DD65FC, retry... warning: wrong data size at 0x00DD65FC, retry... warning: wrong data size at 0x00DD65FC, retry... warning: wrong data size at 0x00DD65FC, retry... warning: wrong data size at 0x00DD65FC, retry... warning: wrong data size at 0x00DD65FC, retry... warning: wrong data size at 0x00DD65FC, retry... warning: wrong data size at 0x00DD65FC, retry... error: too many retries during read operation detect standard fat location pass #2... . detect extended fat location pass #2... . warning: fat location can't be detected error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Finished, time used: 279 sec Remove/Install battery now ! |
11-10-2010, 23:07 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if i am not mistaken- i had similar phone. at the end of testings i returned it to customer. Neither our box nor some other could not work with it properly |
11-10-2010, 23:15 | #10 (permalink) | |
Member: 591880 Status: Offline Thanks Meter: 561 | Quote:
Code: COM12 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [00C0:00C0]... CPU: MT00C0 high speed boot On error: hardware is not supported: [000000C0:000000C0] Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 6 sec Remove/Install battery now ! *what you think -probleme comunication beetwen box and CPU -bad CPU | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
