01-28-2016, 13:54 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: KOLKATA INDIA
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | Intex Aqua R4+ flashing failed Chinese Miracle II [RDA module] v 1.04 Load file... RDATotal : Intex_Aqua_R4+_V05_Indian_SER_20150731_0918_rda_to tal.bin Load Ok Operation : Flash ======= Settings Settings : Factory Settings Enabled ======= Flash Files set for flashing : RDATotal File : Intex_Aqua_R4+_V05_Indian_SER_20150731_0918_rda_to tal.bin Load Ok : PDL1 Load Ok : PDL2 Load Ok : bootloader Load Ok : boot Load Ok : system Load Ok : modem Load Ok : customer Load Ok : recovery Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! [PDL] : Setting FlashMode ... [PDLBoot] : Sending First PDL ... [PDLBoot] : First Boot Ok! [PDLBoot] : Sending Second PDL ... [PDLBoot] : Second Boot Ok! Boot Finished! Handshake with FL Ok! Factory Defaults Enabled, will reset UserData and Settings! Format UDA partition ... Format USER Ok [PDLFlash] : Sending All Images [PDLFlash] : Processing now BOOTLOADER File : Intex_Aqua_R4+_V05_Indian_SER_20150731_0918_rda_to tal.bin Flashing ... [PDLFlash] : Flash region done! [PDLFlash] : Processing now BOOT File : Intex_Aqua_R4+_V05_Indian_SER_20150731_0918_rda_to tal.bin Flashing ... [PDLFlash] : ERROR! PartitionFinalize rejected! Check FlashFile and connection! Flashing Done! Reboot Phone Elapsed: 00:00:28 Reconnect Power/Cable! |
01-29-2016, 12:58 | #5 (permalink) | |
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | Quote:
log here Code: Open port OK! Load Image ok! Send connect[CMD] command ok! WaitForAck [CMD] command ok! Connect the device OK! Start to download the packet files ... ... Start to download pdl1 ... Downloading the data ... Send start command OK !! Send the 1th frame OK!! Send the 2th frame OK!! Send the 3th frame OK!! Send the 4th frame OK!! Send the 5th frame OK!! Send the 6th frame OK!! Send the 7th frame OK!! End PDL1 OK !! Execute PDL1 OK !! Download PDL1 OK !! Start to download pdl2 ... Downloading the data ... Send start command OK !! Send the 1th frame OK!! Send the 2th frame OK!! Send the 3th frame OK!! Send the 4th frame OK!! Send the 5th frame OK!! Send the 6th frame OK!! Send the 7th frame OK!! Send the 8th frame OK!! Send the 9th frame OK!! Send the 10th frame OK!! Send the 11th frame OK!! Send the 12th frame OK!! Send the 13th frame OK!! Send the 14th frame OK!! Send the 15th frame OK!! Send the 16th frame OK!! Send the 17th frame OK!! Send the 18th frame OK!! Send the 19th frame OK!! Send the 20th frame OK!! Send the 21th frame OK!! Send the 22th frame OK!! Send the 23th frame OK!! Send the 24th frame OK!! Send the 25th frame OK!! Send the 26th frame OK!! Send the 27th frame OK!! Send the 28th frame OK!! Send the 29th frame OK!! Send the 30th frame OK!! Send the 31th frame OK!! Send the 32th frame OK!! Send the 33th frame OK!! Send the 34th frame OK!! Send the 35th frame OK!! Send the 36th frame OK!! Send the 37th frame OK!! Send the 38th frame OK!! Send the 39th frame OK!! Send the 40th frame OK!! Send the 41th frame OK!! Send the 42th frame OK!! Send the 43th frame OK!! Send the 44th frame OK!! Send the 45th frame OK!! Send the 46th frame OK!! Send the 47th frame OK!! Send the 48th frame OK!! Send the 49th frame OK!! Send the 50th frame OK!! Send the 51th frame OK!! Send the 52th frame OK!! Send the 53th frame OK!! Send the 54th frame OK!! Send the 55th frame OK!! Send the 56th frame OK!! Send the 57th frame OK!! Send the 58th frame OK!! Send the 59th frame OK!! Send the 60th frame OK!! Send the 61th frame OK!! Send the 62th frame OK!! Send the 63th frame OK!! Send the 64th frame OK!! Send the 65th frame OK!! Send the 66th frame OK!! Send the 67th frame OK!! Send the 68th frame OK!! Send the 69th frame OK!! Send the 70th frame OK!! Send the 71th frame OK!! Send the 72th frame OK!! Send the 73th frame OK!! Send the 74th frame OK!! Send the 75th frame OK!! Send the 76th frame OK!! Send the 77th frame OK!! Send the 78th frame OK!! Send the 79th frame OK!! Send the 80th frame OK!! Send the 81th frame OK!! Send the 82th frame OK!! Send the 83th frame OK!! Send the 84th frame OK!! Send the 85th frame OK!! Send the 86th frame OK!! Send the 87th frame OK!! Send the 88th frame OK!! Send the 89th frame OK!! Send the 90th frame OK!! Send the 91th frame OK!! Send the 92th frame OK!! Send the 93th frame OK!! Send the 94th frame OK!! Send the 95th frame OK!! Send the 96th frame OK!! Send the 97th frame OK!! Send the 98th frame OK!! Send the 99th frame OK!! Send the 100th frame OK!! Send the 101th frame OK!! Send the 102th frame OK!! Send the 103th frame OK!! Send the 104th frame OK!! Send the 105th frame OK!! Send the 106th frame OK!! Send the 107th frame OK!! Send the 108th frame OK!! Send the 109th frame OK!! Send the 110th frame OK!! Send the 111th frame OK!! Send the 112th frame OK!! Send the 113th frame OK!! Send the 114th frame OK!! Send the 115th frame OK!! Send the 116th frame OK!! Send the 117th frame OK!! Send the 118th frame OK!! Send the 119th frame OK!! Send the 120th frame OK!! Send the 121th frame OK!! Send the 122th frame OK!! Send the 123th frame OK!! Send the 124th frame OK!! Send the 125th frame OK!! Send the 126th frame OK!! Send the 127th frame OK!! Send the 128th frame OK!! Send the 129th frame OK!! Send the 130th frame OK!! Send the 131th frame OK!! Send the 132th frame OK!! Send the 133th frame OK!! Send the 134th frame OK!! Send the 135th frame OK!! Send the 136th frame OK!! Send the 137th frame OK!! Send the 138th frame OK!! Send the 139th frame OK!! Send the 140th frame OK!! Send the 141th frame OK!! Send the 142th frame OK!! Send the 143th frame OK!! Send the 144th frame OK!! Send the 145th frame OK!! Send the 146th frame OK!! Send the 147th frame OK!! Send the 148th frame OK!! Send the 149th frame OK!! Send the 150th frame OK!! Send the 151th frame OK!! Send the 152th frame OK!! Send the 153th frame OK!! Send the 154th frame OK!! Send the 155th frame OK!! Send the 156th frame OK!! Send the 157th frame OK!! Send the 158th frame OK!! Send the 159th frame OK!! Send the 160th frame OK!! Send the 161th frame OK!! Send the 162th frame OK!! Send the 163th frame OK!! Send the 164th frame OK!! Send the 165th frame OK!! Send the 166th frame OK!! Send the 167th frame OK!! Send the 168th frame OK!! Send the 169th frame OK!! Send the 170th frame OK!! Send the 171th frame OK!! Send the 172th frame OK!! Send the 173th frame OK!! Send the 174th frame OK!! Send the 175th frame OK!! Send the 176th frame OK!! Send the 177th frame OK!! Send the 178th frame OK!! Send the 179th frame OK!! Send the 180th frame OK!! Send the 181th frame OK!! Send the 182th frame OK!! Send the 183th frame OK!! Send the 184th frame OK!! Send the 185th frame OK!! Send the 186th frame OK!! Send the 187th frame OK!! Send the 188th frame OK!! Send the 189th frame OK!! Send the 190th frame OK!! Send the 191th frame OK!! Send the 192th frame OK!! Send the 193th frame OK!! Send the 194th frame OK!! Send the 195th frame OK!! Send the 196th frame OK!! Send the 197th frame OK!! Send the 198th frame OK!! Send the 199th frame OK!! Send the 200th frame OK!! Send the 201th frame OK!! Send the 202th frame OK!! Send the 203th frame OK!! Send the 204th frame OK!! Send the 205th frame OK!! Send the 206th frame OK!! Send the 207th frame OK!! Send the 208th frame OK!! Send the 209th frame OK!! Send the 210th frame OK!! Send the 211th frame OK!! Send the 212th frame OK!! Send the 213th frame OK!! Send the 214th frame OK!! Send the 215th frame OK!! Send the 216th frame OK!! Send the 217th frame OK!! Send the 218th frame OK!! Send the 219th frame OK!! Send the 220th frame OK!! Send the 221th frame OK!! Send the 222th frame OK!! End PDL2 OK !! Execute PDL2 OK !! Download PDL2 OK !! Read the image info ... Read Image info OK! Start to download bootloader ... Downloading the data ... Send start command OK !! Send the 1th frame OK!! Send the 2th frame OK!! Send the 3th frame OK!! Send the 4th frame OK!! Send the 5th frame OK!! Send the 6th frame OK!! Send the 7th frame OK!! End bootloader OK !! Download bootloader OK !! Start to download boot ... Downloading the data ... Send start command OK !! Send the 1th frame OK!! Send the 2th frame OK!! Send the 3th frame OK!! Send the 4th frame OK!! Send the 5th frame OK!! Send the 6th frame OK!! Send the 7th frame OK!! Send the 8th frame OK!! Send the 9th frame OK!! Send the 10th frame OK!! Send the 11th frame OK!! Send the 12th frame OK!! Send the 13th frame OK!! Send the 14th frame OK!! Send the 15th frame OK!! Send the 16th frame OK!! Send the 17th frame OK!! Send the 18th frame OK!! Send the 19th frame OK!! Send the 20th frame OK!! Send the 21th frame OK!! Send the 22th frame OK!! Send the 23th frame OK!! Send the 24th frame OK!! Send the 25th frame OK!! Send the 26th frame OK!! Send the 27th frame OK!! Send the 28th frame OK!! Send the 29th frame OK!! Send the 30th frame OK!! Send the 31th frame OK!! Send the 32th frame OK!! Send the 33th frame OK!! Send the 34th frame OK!! Send the 35th frame OK!! Send the 36th frame OK!! End boot OK !! Download boot OK !! Start to download system ... Downloading the data ... Send start command OK !! Send the 1th frame OK!! Send the 2th frame OK!! Send the 3th frame OK!! Send the 4th frame OK!! Send the 5th frame OK!! Send the 6th frame OK!! Send the 7th frame OK!! Send the 8th frame OK!! Send the 9th frame OK!! Send the 10th frame OK!! Send the 11th frame OK!! Send the 12th frame OK!! Send the 13th frame OK!! Send the 14th frame OK!! Send the 15th frame OK!! Send the 16th frame OK!! Send the 17th frame OK!! Send the 18th frame OK!! Send the 19th frame OK!! Send the 20th frame OK!! Send the 21th frame OK!! Send the 22th frame OK!! Send the 23th frame OK!! Send the 24th frame OK!! Send the 25th frame OK!! Send the 26th frame OK!! Send the 27th frame OK!! Send the 28th frame OK!! Send the 29th frame OK!! Send the 30th frame OK!! Send the 31th frame OK!! Send the 32th frame OK!! Send the 33th frame OK!! Send the 34th frame OK!! Send the 35th frame OK!! Send the 36th frame OK!! Send the 37th frame OK!! Send the 38th frame OK!! Send the 39th frame OK!! Send the 40th frame OK!! Send the 41th frame OK!! Send the 42th frame OK!! Send the 43th frame OK!! Send the 44th frame OK!! Send the 45th frame OK!! Send the 46th frame OK!! Send the 47th frame OK!! Send the 48th frame OK!! Send the 49th frame OK!! Send the 50th frame OK!! Send the 51th frame OK!! Send the 52th frame OK!! Send the 53th frame OK!! Send the 54th frame OK!! Send the 55th frame OK!! Send the 56th frame OK!! Send the 57th frame OK!! Send the 58th frame OK!! Send the 59th frame OK!! Send the 60th frame OK!! Send the 61th frame OK!! Send the 62th frame OK!! Send the 63th frame OK!! Send the 64th frame OK!! Send the 65th frame OK!! Send the 66th frame OK!! Send the 67th frame OK!! Send the 68th frame OK!! Send the 69th frame OK!! Send the 70th frame OK!! Send the 71th frame OK!! Send the 72th frame OK!! Send the 73th frame OK!! Send the 74th frame OK!! Send the 75th frame OK!! Send the 76th frame OK!! Send the 77th frame OK!! Send the 78th frame OK!! Send the 79th frame OK!! Send the 80th frame OK!! Send the 81th frame OK!! Send the 82th frame OK!! Send the 83th frame OK!! Send the 84th frame OK!! Send the 85th frame OK!! Send the 86th frame OK!! Send the 87th frame OK!! Send the 88th frame OK!! Send the 89th frame OK!! Send the 90th frame OK!! Send the 91th frame OK!! Send the 92th frame OK!! Send the 93th frame OK!! Send the 94th frame OK!! Send the 95th frame OK!! Send the 96th frame OK!! Send the 97th frame OK!! Send the 98th frame OK!! Send the 99th frame OK!! Send the 100th frame OK!! Send the 101th frame OK!! Send the 102th frame OK!! Send the 103th frame OK!! Send the 104th frame OK!! Send the 105th frame OK!! Send the 106th frame OK!! Send the 107th frame OK!! Send the 108th frame OK!! Send the 109th frame OK!! Send the 110th frame OK!! Send the 111th frame OK!! Send the 112th frame OK!! Send the 113th frame OK!! Send the 114th frame OK!! Send the 115th frame OK!! Send the 116th frame OK!! Send the 117th frame OK!! Send the 118th frame OK!! Send the 119th frame OK!! Send the 120th frame OK!! Send the 121th frame OK!! Send the 122th frame OK!! Send the 123th frame OK!! Send the 124th frame OK!! Send the 125th frame OK!! Send the 126th frame OK!! Send the 127th frame OK!! Send the 128th frame OK!! Send the 129th frame OK!! Send the 130th frame OK!! Send the 131th frame OK!! Send the 132th frame OK!! Send the 133th frame OK!! Send the 134th frame OK!! Send the 135th frame OK!! Send the 136th frame OK!! Send the 137th frame OK!! Send the 138th frame OK!! Send the 139th frame OK!! Send the 140th frame OK!! Send the 141th frame OK!! Send the 142th frame OK!! Send the 143th frame OK!! Send the 144th frame OK!! Send the 145th frame OK!! Send the 146th frame OK!! Send the 147th frame OK!! Send the 148th frame OK!! Send the 149th frame OK!! Send the 150th frame OK!! Send the 151th frame OK!! Send the 152th frame OK!! Send the 153th frame OK!! Send the 154th frame OK!! Send the 155th frame OK!! Send the 156th frame OK!! Send the 157th frame OK!! Send the 158th frame OK!! Send the 159th frame OK!! Send the 160th frame OK!! Send the 161th frame OK!! Send the 162th frame OK!! Send the 163th frame OK!! Send the 164th frame OK!! Send the 165th frame OK!! Send the 166th frame OK!! Send the 167th frame OK!! Send the 168th frame OK!! Send the 169th frame OK!! Send the 170th frame OK!! Send the 171th frame OK!! Send the 172th frame OK!! Send the 173th frame OK!! Send the 174th frame OK!! Send the 175th frame OK!! Send the 176th frame OK!! Send the 177th frame OK!! Send the 178th frame OK!! Send the 179th frame OK!! Send the 180th frame OK!! Send the 181th frame OK!! Send the 182th frame OK!! Send the 183th frame OK!! Send the 184th frame OK!! Send the 185th frame OK!! Send the 186th frame OK!! Send the 187th frame OK!! Send the 188th frame OK!! Send the 189th frame OK!! Send the 190th frame OK!! Send the 191th frame OK!! Send the 192th frame OK!! Send the 193th frame OK!! Send the 194th frame OK!! Send the 195th frame OK!! Send the 196th frame OK!! Send the 197th frame OK!! Send the 198th frame OK!! Send the 199th frame OK!! Send the 200th frame OK!! Send the 201th frame OK!! Send the 202th frame OK!! Send the 203th frame OK!! Send the 204th frame OK!! Send the 205th frame OK!! Send the 206th frame OK!! Send the 207th frame OK!! Send the 208th frame OK!! Send the 209th frame OK!! Send the 210th frame OK!! Send the 211th frame OK!! Send the 212th frame OK!! Send the 213th frame OK!! Send the 214th frame OK!! Send the 215th frame OK!! Send the 216th frame OK!! Send the 217th frame OK!! Send the 218th frame OK!! Send the 219th frame OK!! Send the 220th frame OK!! Send the 221th frame OK!! Send the 222th frame OK!! Send the 223th frame OK!! Send the 224th frame OK!! Send the 225th frame OK!! Send the 226th frame OK!! Send the 227th frame OK!! Send the 228th frame OK!! Send the 229th frame OK!! Send the 230th frame OK!! Send the 231th frame OK!! Send the 232th frame OK!! Send the 233th frame OK!! Send the 234th frame OK!! Send the 235th frame OK!! Send the 236th frame OK!! Send the 237th frame OK!! Send the 238th frame OK!! Send the 239th frame OK!! Send the 240th frame OK!! Send the 241th frame OK!! Send the 242th frame OK!! Send the 243th frame OK!! Send the 244th frame OK!! Send the 245th frame OK!! Send the 246th frame OK!! Send the 247th frame OK!! Send the 248th frame OK!! Send the 249th frame OK!! Send the 250th frame OK!! Send the 251th frame OK!! Send the 252th frame OK!! Send the 253th frame OK!! Send the 254th frame OK!! Send the 255th frame OK!! Send the 256th frame OK!! Send the 257th frame OK!! Send the 258th frame OK!! Send the 259th frame OK!! Send the 260th frame OK!! Send the 261th frame OK!! Send the 262th frame OK!! Send the 263th frame OK!! Send the 264th frame OK!! Send the 265th frame OK!! Send the 266th frame OK!! Send the 267th frame OK!! Send the 268th frame OK!! Send the 269th frame OK!! Send the 270th frame OK!! Send the 271th frame OK!! Send the 272th frame OK!! Send the 273th frame OK!! Send the 274th frame OK!! Send the 275th frame OK!! Send the 276th frame OK!! Send the 277th frame OK!! Send the 278th frame OK!! Send the 279th frame OK!! Send the 280th frame OK!! Send the 281th frame OK!! Send the 282th frame OK!! Send the 283th frame OK!! Send the 284th frame OK!! Send the 285th frame OK!! Send the 286th frame OK!! Send the 287th frame OK!! Send the 288th frame OK!! Send the 289th frame OK!! Send the 290th frame OK!! Send the 291th frame OK!! Send the 292th frame OK!! Send the 293th frame OK!! Send the 294th frame OK!! Send the 295th frame OK!! Send the 296th frame OK!! Send the 297th frame OK!! Send the 298th frame OK!! Send the 299th frame OK!! Send the 300th frame OK!! Send the 301th frame OK!! Send the 302th frame OK!! Send the 303th frame OK!! Send the 304th frame OK!! Send the 305th frame OK!! Send the 306th frame OK!! Send the 307th frame OK!! Send the 308th frame OK!! Send the 309th frame OK!! Send the 310th frame OK!! Send the 311th frame OK!! Send the 312th frame OK!! Send the 313th frame OK!! Send the 314th frame OK!! Send the 315th frame OK!! Send the 316th frame OK!! Send the 317th frame OK!! Send the 318th frame OK!! Send the 319th frame OK!! Send the 320th frame OK!! Send the 321th frame OK!! Send the 322th frame OK!! Send the 323th frame OK!! Send the 324th frame OK!! Send the 325th frame OK!! Send the 326th frame OK!! Send the 327th frame OK!! Send the 328th frame OK!! Send the 329th frame OK!! Send the 330th frame OK!! Send the 331th frame OK!! Send the 332th frame OK!! Send the 333th frame OK!! Send the 334th frame OK!! Send the 335th frame OK!! Send the 336th frame OK!! Send the 337th frame OK!! Send the 338th frame OK!! Send the 339th frame OK!! Send the 340th frame OK!! Send the 341th frame OK!! Send the 342th frame OK!! Send the 343th frame OK!! Send the 344th frame OK!! Send the 345th frame OK!! Send the 346th frame OK!! Send the 347th frame OK!! Send the 348th frame OK!! Send the 349th frame OK!! Send the 350th frame OK!! Send the 351th frame OK!! Send the 352th frame OK!! Send the 353th frame OK!! Send the 354th frame OK!! Send the 355th frame OK!! Send the 356th frame OK!! Send the 357th frame OK!! Send the 358th frame OK!! Send the 359th frame OK!! Send the 360th frame OK!! Send the 361th frame OK!! Send the 362th frame OK!! Send the 363th frame OK!! Send the 364th frame OK!! Send the 365th frame OK!! Send the 366th frame OK!! Send the 367th frame OK!! Send the 368th frame OK!! Send the 369th frame OK!! Send the 370th frame OK!! Send the 371th frame OK!! Send the 372th frame OK!! Send the 373th frame OK!! Send the 374th frame OK!! Send the 375th frame OK!! Send the 376th frame OK!! Send the 377th frame OK!! Send the 378th frame OK!! Send the 379th frame OK!! Send the 380th frame OK!! Send the 381th frame OK!! Send the 382th frame OK!! Send the 383th frame OK!! Send the 384th frame OK!! Send the 385th frame OK!! Send the 386th frame OK!! Send the 387th frame OK!! Send the 388th frame OK!! Send the 389th frame OK!! Send the 390th frame OK!! Send the 391th frame OK!! Send the 392th frame OK!! Send the 393th frame OK!! Send the 394th frame OK!! Send the 395th frame OK!! Send the 396th frame OK!! Send the 397th frame OK!! Send the 398th frame OK!! Send the 399th frame OK!! Send the 400th frame OK!! Send the 401th frame OK!! Send the 402th frame OK!! Send the 403th frame OK!! Send the 404th frame OK!! Send the 405th frame OK!! Send the 406th frame OK!! Send the 407th frame OK!! Send the 408th frame OK!! Send the 409th frame OK!! Send the 410th frame OK!! Send the 411th frame OK!! Send the 412th frame OK!! Send the 413th frame OK!! Send the 414th frame OK!! Send the 415th frame OK!! Send the 416th frame OK!! Send the 417th frame OK!! Send the 418th frame OK!! Send the 419th frame OK!! Send the 420th frame OK!! Send the 421th frame OK!! Send the 422th frame OK!! Send the 423th frame OK!! Send the 424th frame OK!! Send the 425th frame OK!! Send the 426th frame OK!! Send the 427th frame OK!! Send the 428th frame OK!! Send the 429th frame OK!! Send the 430th frame OK!! Send the 431th frame OK!! Send the 432th frame OK!! Send the 433th frame OK!! Send the 434th frame OK!! Send the 435th frame OK!! Send the 436th frame OK!! Send the 437th frame OK!! Send the 438th frame OK!! Send the 439th frame OK!! Send the 440th frame OK!! Send the 441th frame OK!! Send the 442th frame OK!! Send the 443th frame OK!! Send the 444th frame OK!! Send the 445th frame OK!! Send the 446th frame OK!! Send the 447th frame OK!! Send the 448th frame OK!! Send the 449th frame OK!! Send the 450th frame OK!! Send the 451th frame OK!! Send the 452th frame OK!! Send the 453th frame OK!! Send the 454th frame OK!! Send the 455th frame OK!! Send the 456th frame OK!! Send the 457th frame OK!! Send the 458th frame OK!! Send the 459th frame OK!! Send the 460th frame OK!! Send the 461th frame OK!! Send the 462th frame OK!! Send the 463th frame OK!! Send the 464th frame OK!! Send the 465th frame OK!! Send the 466th frame OK!! Send the 467th frame OK!! Send the 468th frame OK!! Send the 469th frame OK!! Send the 470th frame OK!! Send the 471th frame OK!! Send the 472th frame OK!! Send the 473th frame OK!! Send the 474th frame OK!! Send the 475th frame OK!! Send the 476th frame OK!! Send the 477th frame OK!! Send the 478th frame OK!! Send the 479th frame OK!! Send the 480th frame OK!! Send the 481th frame OK!! Send the 482th frame OK!! Send the 483th frame OK!! Send the 484th frame OK!! Send the 485th frame OK!! Send the 486th frame OK!! Send the 487th frame OK!! Send the 488th frame OK!! Send the 489th frame OK!! Send the 490th frame OK!! Send the 491th frame OK!! Send the 492th frame OK!! Send the 493th frame OK!! Send the 494th frame OK!! Send the 495th frame OK!! Send the 496th frame OK!! Send the 497th frame OK!! Send the 498th frame OK!! Send the 499th frame OK!! Send the 500th frame OK!! Send the 501th frame OK!! Send the 502th frame OK!! Send the 503th frame OK!! Send the 504th frame OK!! Send the 505th frame OK!! Send the 506th frame OK!! Send the 507th frame OK!! Send the 508th frame OK!! Send the 509th frame OK!! Send the 510th frame OK!! Send the 511th frame OK!! Send the 512th frame OK!! Send the 513th frame OK!! Send the 514th frame OK!! Send the 515th frame OK!! Send the 516th frame OK!! Send the 517th frame OK!! Send the 518th frame OK!! Send the 519th frame OK!! Send the 520th frame OK!! Send the 521th frame OK!! Send the 522th frame OK!! Send the 523th frame OK!! Send the 524th frame OK!! Send the 525th frame OK!! Send the 526th frame OK!! Send the 527th frame OK!! Send the 528th frame OK!! Send the 529th frame OK!! Send the 530th frame OK!! Send the 531th frame OK!! Send the 532th frame OK!! Send the 533th frame OK!! Send the 534th frame OK!! Send the 535th frame OK!! Send the 536th frame OK!! Send the 537th frame OK!! Send the 538th frame OK!! Send the 539th frame OK!! Send the 540th frame OK!! Send the 541th frame OK!! Send the 542th frame OK!! Send the 543th frame OK!! Send the 544th frame OK!! Send the 545th frame OK!! Send the 546th frame OK!! Send the 547th frame OK!! Send the 548th frame OK!! Send the 549th frame OK!! Send the 550th frame OK!! Send the 551th frame OK!! Send the 552th frame OK!! Send the 553th frame OK!! Send the 554th frame OK!! Send the 555th frame OK!! Send the 556th frame OK!! Send the 557th frame OK!! Send the 558th frame OK!! Send the 559th frame OK!! Send the 560th frame OK!! Send the 561th frame OK!! Send the 562th frame OK!! Send the 563th frame OK!! Send the 564th frame OK!! Send the 565th frame OK!! Send the 566th frame OK!! Send the 567th frame OK!! Send the 568th frame OK!! Send the 569th frame OK!! Send the 570th frame OK!! Send the 571th frame OK!! Send the 572th frame OK!! Send the 573th frame OK!! Send the 574th frame OK!! Send the 575th frame OK!! Send the 576th frame OK!! Send the 577th frame OK!! Send the 578th frame OK!! Send the 579th frame OK!! Send the 580th frame OK!! Send the 581th frame OK!! Send the 582th frame OK!! Send the 583th frame OK!! Send the 584th frame OK!! Send the 585th frame OK!! Send the 586th frame OK!! Send the 587th frame OK!! Send the 588th frame OK!! End system OK !! Download system OK !! Start to download modem ... Downloading the data ... Send start command OK !! Send the 1th frame OK!! Send the 2th frame OK!! Send the 3th frame OK!! Send the 4th frame OK!! Send the 5th frame OK!! Send the 6th frame OK!! Send the 7th frame OK!! Send the 8th frame OK!! Send the 9th frame OK!! Send the 10th frame OK!! Send the 11th frame OK!! Send the 12th frame OK!! Send the 13th frame OK!! Send the 14th frame OK!! Send the 15th frame OK!! Send the 16th frame OK!! End modem OK !! Download modem OK !! Start to download customer ... Downloading the data ... Send start command OK !! Send the 1th frame OK!! Send the 2th frame OK!! Send the 3th frame OK!! Send the 4th frame OK!! Send the 5th frame OK!! Send the 6th frame OK!! Send the 7th frame OK!! Send the 8th frame OK!! Send the 9th frame OK!! Send the 10th frame OK!! Send the 11th frame OK!! Send the 12th frame OK!! Send the 13th frame OK!! Send the 14th frame OK!! Send the 15th frame OK!! Send the 16th frame OK!! Send the 17th frame OK!! Send the 18th frame OK!! Send the 19th frame OK!! Send the 20th frame OK!! Send the 21th frame OK!! Send the 22th frame OK!! Send the 23th frame OK!! Send the 24th frame OK!! Send the 25th frame OK!! Send the 26th frame OK!! Send the 27th frame OK!! Send the 28th frame OK!! Send the 29th frame OK!! Send the 30th frame OK!! Send the 31th frame OK!! Send the 32th frame OK!! Send the 33th frame OK!! Send the 34th frame OK!! Send the 35th frame OK!! Send the 36th frame OK!! Send the 37th frame OK!! Send the 38th frame OK!! Send the 39th frame OK!! Send the 40th frame OK!! Send the 41th frame OK!! Send the 42th frame OK!! Send the 43th frame OK!! Send the 44th frame OK!! Send the 45th frame OK!! Send the 46th frame OK!! Send the 47th frame OK!! Send the 48th frame OK!! Send the 49th frame OK!! Send the 50th frame OK!! Send the 51th frame OK!! Send the 52th frame OK!! Send the 53th frame OK!! Send the 54th frame OK!! Send the 55th frame OK!! Send the 56th frame OK!! Send the 57th frame OK!! Send the 58th frame OK!! Send the 59th frame OK!! Send the 60th frame OK!! Send the 61th frame OK!! Send the 62th frame OK!! Send the 63th frame OK!! Send the 64th frame OK!! Send the 65th frame OK!! Send the 66th frame OK!! Send the 67th frame OK!! Send the 68th frame OK!! Send the 69th frame OK!! Send the 70th frame OK!! Send the 71th frame OK!! Send the 72th frame OK!! Send the 73th frame OK!! Send the 74th frame OK!! Send the 75th frame OK!! Send the 76th frame OK!! Send the 77th frame OK!! Send the 78th frame OK!! Send the 79th frame OK!! Send the 80th frame OK!! Send the 81th frame OK!! Send the 82th frame OK!! Send the 83th frame OK!! Send the 84th frame OK!! Send the 85th frame OK!! Send the 86th frame OK!! Send the 87th frame OK!! Send the 88th frame OK!! Send the 89th frame OK!! Send the 90th frame OK!! Send the 91th frame OK!! Send the 92th frame OK!! Send the 93th frame OK!! Send the 94th frame OK!! Send the 95th frame OK!! Send the 96th frame OK!! Send the 97th frame OK!! Send the 98th frame OK!! Send the 99th frame OK!! Send the 100th frame OK!! Send the 101th frame OK!! Send the 102th frame OK!! Send the 103th frame OK!! Send the 104th frame OK!! Send the 105th frame OK!! Send the 106th frame OK!! Send the 107th frame OK!! Send the 108th frame OK!! Send the 109th frame OK!! Send the 110th frame OK!! Send the 111th frame OK!! Send the 112th frame OK!! Send the 113th frame OK!! Send the 114th frame OK!! Send the 115th frame OK!! Send the 116th frame OK!! Send the 117th frame OK!! Send the 118th frame OK!! Send the 119th frame OK!! Send the 120th frame OK!! Send the 121th frame OK!! Send the 122th frame OK!! Send the 123th frame OK!! Send the 124th frame OK!! Send the 125th frame OK!! Send the 126th frame OK!! Send the 127th frame OK!! Send the 128th frame OK!! Send the 129th frame OK!! Send the 130th frame OK!! Send the 131th frame OK!! Send the 132th frame OK!! Send the 133th frame OK!! Send the 134th frame OK!! Send the 135th frame OK!! Send the 136th frame OK!! Send the 137th frame OK!! Send the 138th frame OK!! Send the 139th frame OK!! Send the 140th frame OK!! Send the 141th frame OK!! Send the 142th frame OK!! Send the 143th frame OK!! Send the 144th frame OK!! Send the 145th frame OK!! Send the 146th frame OK!! Send the 147th frame OK!! Send the 148th frame OK!! Send the 149th frame OK!! Send the 150th frame OK!! Send the 151th frame OK!! Send the 152th frame OK!! Send the 153th frame OK!! Send the 154th frame OK!! Send the 155th frame OK!! Send the 156th frame OK!! Send the 157th frame OK!! Send the 158th frame OK!! Send the 159th frame OK!! Send the 160th frame OK!! Send the 161th frame OK!! Send the 162th frame OK!! Send the 163th frame OK!! Send the 164th frame OK!! Send the 165th frame OK!! Send the 166th frame OK!! Send the 167th frame OK!! Send the 168th frame OK!! Send the 169th frame OK!! Send the 170th frame OK!! Send the 171th frame OK!! Send the 172th frame OK!! Send the 173th frame OK!! Send the 174th frame OK!! Send the 175th frame OK!! Send the 176th frame OK!! Send the 177th frame OK!! Send the 178th frame OK!! Send the 179th frame OK!! Send the 180th frame OK!! Send the 181th frame OK!! Send the 182th frame OK!! Send the 183th frame OK!! Send the 184th frame OK!! Send the 185th frame OK!! Send the 186th frame OK!! Send the 187th frame OK!! Send the 188th frame OK!! Send the 189th frame OK!! Send the 190th frame OK!! Send the 191th frame OK!! Send the 192th frame OK!! Send the 193th frame OK!! Send the 194th frame OK!! Send the 195th frame OK!! Send the 196th frame OK!! Send the 197th frame OK!! Send the 198th frame OK!! Send the 199th frame OK!! Send the 200th frame OK!! Send the 201th frame OK!! Send the 202th frame OK!! Send the 203th frame OK!! Send the 204th frame OK!! Send the 205th frame OK!! Send the 206th frame OK!! Send the 207th frame OK!! Send the 208th frame OK!! Send the 209th frame OK!! Send the 210th frame OK!! Send the 211th frame OK!! Send the 212th frame OK!! Send the 213th frame OK!! Send the 214th frame OK!! Send the 215th frame OK!! Send the 216th frame OK!! Send the 217th frame OK!! Send the 218th frame OK!! Send the 219th frame OK!! Send the 220th frame OK!! Send the 221th frame OK!! Send the 222th frame OK!! Send the 223th frame OK!! Send the 224th frame OK!! Send the 225th frame OK!! Send the 226th frame OK!! Send the 227th frame OK!! Send the 228th frame OK!! Send the 229th frame OK!! Send the 230th frame OK!! Send the 231th frame OK!! Send the 232th frame OK!! Send the 233th frame OK!! Send the 234th frame OK!! Send the 235th frame OK!! Send the 236th frame OK!! Send the 237th frame OK!! Send the 238th frame OK!! Send the 239th frame OK!! Send the 240th frame OK!! Send the 241th frame OK!! Send the 242th frame OK!! Send the 243th frame OK!! Send the 244th frame OK!! Send the 245th frame OK!! Send the 246th frame OK!! Send the 247th frame OK!! Send the 248th frame OK!! Send the 249th frame OK!! Send the 250th frame OK!! Send the 251th frame OK!! Send the 252th frame OK!! Send the 253th frame OK!! Send the 254th frame OK!! Send the 255th frame OK!! Send the 256th frame OK!! Send the 257th frame OK!! Send the 258th frame OK!! Send the 259th frame OK!! Send the 260th frame OK!! Send the 261th frame OK!! Send the 262th frame OK!! Send the 263th frame OK!! Send the 264th frame OK!! Send the 265th frame OK!! Send the 266th frame OK!! Send the 267th frame OK!! Send the 268th frame OK!! Send the 269th frame OK!! Send the 270th frame OK!! Send the 271th frame OK!! Send the 272th frame OK!! Send the 273th frame OK!! Send the 274th frame OK!! Send the 275th frame OK!! Send the 276th frame OK!! Send the 277th frame OK!! Send the 278th frame OK!! Send the 279th frame OK!! Send the 280th frame OK!! Send the 281th frame OK!! Send the 282th frame OK!! Send the 283th frame OK!! Send the 284th frame OK!! Send the 285th frame OK!! Send the 286th frame OK!! Send the 287th frame OK!! Send the 288th frame OK!! Send the 289th frame OK!! Send the 290th frame OK!! Send the 291th frame OK!! Send the 292th frame OK!! Send the 293th frame OK!! Send the 294th frame OK!! Send the 295th frame OK!! Send the 296th frame OK!! Send the 297th frame OK!! Send the 298th frame OK!! Send the 299th frame OK!! Send the 300th frame OK!! Send the 301th frame OK!! Send the 302th frame OK!! Send the 303th frame OK!! Send the 304th frame OK!! Send the 305th frame OK!! Send the 306th frame OK!! Send the 307th frame OK!! Send the 308th frame OK!! Send the 309th frame OK!! Send the 310th frame OK!! Send the 311th frame OK!! Send the 312th frame OK!! Send the 313th frame OK!! Send the 314th frame OK!! Send the 315th frame OK!! Send the 316th frame OK!! Send the 317th frame OK!! Send the 318th frame OK!! Send the 319th frame OK!! Send the 320th frame OK!! Send the 321th frame OK!! Send the 322th frame OK!! Send the 323th frame OK!! Send the 324th frame OK!! Send the 325th frame OK!! Send the 326th frame OK!! Send the 327th frame OK!! Send the 328th frame OK!! Send the 329th frame OK!! Send the 330th frame OK!! Send the 331th frame OK!! Send the 332th frame OK!! Send the 333th frame OK!! Send the 334th frame OK!! Send the 335th frame OK!! Send the 336th frame OK!! Send the 337th frame OK!! Send the 338th frame OK!! Send the 339th frame OK!! Send the 340th frame OK!! Send the 341th frame OK!! Send the 342th frame OK!! Send the 343th frame OK!! Send the 344th frame OK!! Send the 345th frame OK!! Send the 346th frame OK!! Send the 347th frame OK!! Send the 348th frame OK!! Send the 349th frame OK!! Send the 350th frame OK!! Send the 351th frame OK!! Send the 352th frame OK!! Send the 353th frame OK!! Send the 354th frame OK!! Send the 355th frame OK!! Send the 356th frame OK!! Send the 357th frame OK!! Send the 358th frame OK!! Send the 359th frame OK!! Send the 360th frame OK!! Send the 361th frame OK!! Send the 362th frame OK!! Send the 363th frame OK!! Send the 364th frame OK!! Send the 365th frame OK!! Send the 366th frame OK!! Send the 367th frame OK!! Send the 368th frame OK!! Send the 369th frame OK!! Send the 370th frame OK!! Send the 371th frame OK!! Send the 372th frame OK!! Send the 373th frame OK!! Send the 374th frame OK!! Send the 375th frame OK!! Send the 376th frame OK!! Send the 377th frame OK!! Send the 378th frame OK!! Send the 379th frame OK!! Send the 380th frame OK!! Send the 381th frame OK!! Send the 382th frame OK!! Send the 383th frame OK!! Send the 384th frame OK!! Send the 385th frame OK!! Send the 386th frame OK!! Send the 387th frame OK!! Send the 388th frame OK!! Send the 389th frame OK!! Send the 390th frame OK!! Send the 391th frame OK!! Send the 392th frame OK!! Send the 393th frame OK!! Send the 394th frame OK!! Send the 395th frame OK!! Send the 396th frame OK!! Send the 397th frame OK!! Send the 398th frame OK!! Send the 399th frame OK!! Send the 400th frame OK!! Send the 401th frame OK!! Send the 402th frame OK!! Send the 403th frame OK!! Send the 404th frame OK!! Send the 405th frame OK!! Send the 406th frame OK!! Send the 407th frame OK!! Send the 408th frame OK!! Send the 409th frame OK!! Send the 410th frame OK!! Send the 411th frame OK!! Send the 412th frame OK!! Send the 413th frame OK!! Send the 414th frame OK!! Send the 415th frame OK!! Send the 416th frame OK!! Send the 417th frame OK!! Send the 418th frame OK!! Send the 419th frame OK!! Send the 420th frame OK!! Send the 421th frame OK!! Send the 422th frame OK!! Send the 423th frame OK!! Send the 424th frame OK!! Send the 425th frame OK!! Send the 426th frame OK!! Send the 427th frame OK!! Send the 428th frame OK!! Send the 429th frame OK!! Send the 430th frame OK!! Send the 431th frame OK!! Send the 432th frame OK!! Send the 433th frame OK!! Send the 434th frame OK!! Send the 435th frame OK!! Send the 436th frame OK!! Send the 437th frame OK!! Send the 438th frame OK!! Send the 439th frame OK!! Send the 440th frame OK!! Send the 441th frame OK!! Send the 442th frame OK!! Send the 443th frame OK!! Send the 444th frame OK!! Send the 445th frame OK!! Send the 446th frame OK!! Send the 447th frame OK!! Send the 448th frame OK!! Send the 449th frame OK!! Send the 450th frame OK!! Send the 451th frame OK!! Send the 452th frame OK!! Send the 453th frame OK!! Send the 454th frame OK!! Send the 455th frame OK!! Send the 456th frame OK!! Send the 457th frame OK!! Send the 458th frame OK!! Send the 459th frame OK!! Send the 460th frame OK!! Send the 461th frame OK!! Send the 462th frame OK!! Send the 463th frame OK!! Send the 464th frame OK!! Send the 465th frame OK!! Send the 466th frame OK!! Send the 467th frame OK!! Send the 468th frame OK!! Send the 469th frame OK!! Send the 470th frame OK!! Send the 471th frame OK!! Send the 472th frame OK!! Send the 473th frame OK!! Send the 474th frame OK!! Send the 475th frame OK!! Send the 476th frame OK!! Send the 477th frame OK!! Send the 478th frame OK!! Send the 479th frame OK!! Send the 480th frame OK!! Send the 481th frame OK!! Send the 482th frame OK!! Send the 483th frame OK!! Send the 484th frame OK!! Send the 485th frame OK!! Send the 486th frame OK!! Send the 487th frame OK!! Send the 488th frame OK!! Send the 489th frame OK!! Send the 490th frame OK!! Send the 491th frame OK!! Send the 492th frame OK!! Send the 493th frame OK!! Send the 494th frame OK!! Send the 495th frame OK!! Send the 496th frame OK!! Send the 497th frame OK!! Send the 498th frame OK!! Send the 499th frame OK!! Send the 500th frame OK!! Send the 501th frame OK!! Send the 502th frame OK!! Send the 503th frame OK!! Send the 504th frame OK!! Send the 505th frame OK!! Send the 506th frame OK!! Send the 507th frame OK!! Send the 508th frame OK!! Send the 509th frame OK!! Send the 510th frame OK!! Send the 511th frame OK!! Send the 512th frame OK!! Send the 513th frame OK!! Send the 514th frame OK!! Send the 515th frame OK!! Send the 516th frame OK!! Send the 517th frame OK!! Send the 518th frame OK!! Send the 519th frame OK!! Send the 520th frame OK!! Send the 521th frame OK!! Send the 522th frame OK!! Send the 523th frame OK!! Send the 524th frame OK!! Send the 525th frame OK!! Send the 526th frame OK!! Send the 527th frame OK!! Send the 528th frame OK!! Send the 529th frame OK!! Send the 530th frame OK!! Send the 531th frame OK!! Send the 532th frame OK!! Send the 533th frame OK!! Send the 534th frame OK!! Send the 535th frame OK!! Send the 536th frame OK!! Send the 537th frame OK!! Send the 538th frame OK!! Send the 539th frame OK!! Send the 540th frame OK!! Send the 541th frame OK!! Send the 542th frame OK!! Send the 543th frame OK!! Send the 544th frame OK!! Send the 545th frame OK!! Send the 546th frame OK!! Send the 547th frame OK!! Send the 548th frame OK!! Send the 549th frame OK!! Send the 550th frame OK!! Send the 551th frame OK!! Send the 552th frame OK!! Send the 553th frame OK!! Send the 554th frame OK!! Send the 555th frame OK!! Send the 556th frame OK!! Send the 557th frame OK!! Send the 558th frame OK!! Send the 559th frame OK!! Send the 560th frame OK!! Send the 561th frame OK!! Send the 562th frame OK!! Send the 563th frame OK!! Send the 564th frame OK!! Send the 565th frame OK!! Send the 566th frame OK!! Send the 567th frame OK!! Send the 568th frame OK!! Send the 569th frame OK!! Send the 570th frame OK!! Send the 571th frame OK!! Send the 572th frame OK!! Send the 573th frame OK!! Send the 574th frame OK!! Send the 575th frame OK!! Send the 576th frame OK!! Send the 577th frame OK!! Send the 578th frame OK!! Send the 579th frame OK!! Send the 580th frame OK!! Send the 581th frame OK!! Send the 582th frame OK!! Send the 583th frame OK!! Send the 584th frame OK!! Send the 585th frame OK!! Send the 586th frame OK!! Send the 587th frame OK!! Send the 588th frame OK!! Send the 589th frame OK!! Send the 590th frame OK!! Send the 591th frame OK!! Send the 592th frame OK!! Send the 593th frame OK!! Send the 594th frame OK!! Send the 595th frame OK!! Send the 596th frame OK!! Send the 597th frame OK!! Send the 598th frame OK!! Send the 599th frame OK!! Send the 600th frame OK!! Send the 601th frame OK!! Send the 602th frame OK!! Send the 603th frame OK!! Send the 604th frame OK!! Send the 605th frame OK!! Send the 606th frame OK!! Send the 607th frame OK!! Send the 608th frame OK!! Send the 609th frame OK!! Send the 610th frame OK!! Send the 611th frame OK!! Send the 612th frame OK!! Send the 613th frame OK!! Send the 614th frame OK!! Send the 615th frame OK!! Send the 616th frame OK!! Send the 617th frame OK!! Send the 618th frame OK!! Send the 619th frame OK!! Send the 620th frame OK!! Send the 621th frame OK!! Send the 622th frame OK!! Send the 623th frame OK!! Send the 624th frame OK!! Send the 625th frame OK!! Send the 626th frame OK!! Send the 627th frame OK!! Send the 628th frame OK!! Send the 629th frame OK!! Send the 630th frame OK!! Send the 631th frame OK!! Send the 632th frame OK!! Send the 633th frame OK!! Send the 634th frame OK!! Send the 635th frame OK!! Send the 636th frame OK!! Send the 637th frame OK!! Send the 638th frame OK!! Send the 639th frame OK!! Send the 640th frame OK!! Send the 641th frame OK!! Send the 642th frame OK!! Send the 643th frame OK!! Send the 644th frame OK!! Send the 645th frame OK!! Send the 646th frame OK!! Send the 647th frame OK!! Send the 648th frame OK!! Send the 649th frame OK!! Send the 650th frame OK!! Send the 651th frame OK!! Send the 652th frame OK!! Send the 653th frame OK!! Send the 654th frame OK!! Send the 655th frame OK!! Send the 656th frame OK!! Send the 657th frame OK!! Send the 658th frame OK!! Send the 659th frame OK!! Send the 660th frame OK!! Send the 661th frame OK!! Send the 662th frame OK!! Send the 663th frame OK!! Send the 664th frame OK!! Send the 665th frame OK!! Send the 666th frame OK!! Send the 667th frame OK!! Send the 668th frame OK!! Send the 669th frame OK!! Send the 670th frame OK!! Send the 671th frame OK!! Send the 672th frame OK!! Send the 673th frame OK!! Send the 674th frame OK!! Send the 675th frame OK!! Send the 676th frame OK!! Send the 677th frame OK!! Send the 678th frame OK!! Send the 679th frame OK!! Send the 680th frame OK!! Send the 681th frame OK!! Send the 682th frame OK!! Send the 683th frame OK!! Send the 684th frame OK!! Send the 685th frame OK!! Send the 686th frame OK!! Send the 687th frame OK!! Send the 688th frame OK!! Send the 689th frame OK!! Send the 690th frame OK!! Send the 691th frame OK!! Send the 692th frame OK!! Send the 693th frame OK!! Send the 694th frame OK!! Send the 695th frame OK!! Send the 696th frame OK!! Send the 697th frame OK!! Send the 698th frame OK!! Send the 699th frame OK!! Send the 700th frame OK!! Send the 701th frame OK!! Send the 702th frame OK!! Send the 703th frame OK!! Send the 704th frame OK!! Send the 705th frame OK!! Send the 706th frame OK!! Send the 707th frame OK!! Send the 708th frame OK!! Send the 709th frame OK!! Send the 710th frame OK!! Send the 711th frame OK!! Send the 712th frame OK!! Send the 713th frame OK!! Send the 714th frame OK!! Send the 715th frame OK!! Send the 716th frame OK!! Send the 717th frame OK!! Send the 718th frame OK!! Send the 719th frame OK!! Send the 720th frame OK!! Send the 721th frame OK!! Send the 722th frame OK!! Send the 723th frame OK!! Send the 724th frame OK!! Send the 725th frame OK!! Send the 726th frame OK!! Send the 727th frame OK!! Send the 728th frame OK!! Send the 729th frame OK!! Send the 730th frame OK!! Send the 731th frame OK!! Send the 732th frame OK!! Send the 733th frame OK!! Send the 734th frame OK!! Send the 735th frame OK!! Send the 736th frame OK!! Send the 737th frame OK!! Send the 738th frame OK!! Send the 739th frame OK!! Send the 740th frame OK!! Send the 741th frame OK!! Send the 742th frame OK!! Send the 743th frame OK!! Send the 744th frame OK!! Send the 745th frame OK!! Send the 746th frame OK!! Send the 747th frame OK!! Send the 748th frame OK!! Send the 749th frame OK!! Send the 750th frame OK!! Send the 751th frame OK!! Send the 752th frame OK!! Send the 753th frame OK!! Send the 754th frame OK!! Send the 755th frame OK!! Send the 756th frame OK!! Send the 757th frame OK!! Send the 758th frame OK!! Send the 759th frame OK!! Send the 760th frame OK!! Send the 761th frame OK!! Send the 762th frame OK!! Send the 763th frame OK!! Send the 764th frame OK!! Send the 765th frame OK!! Send the 766th frame OK!! Send the 767th frame OK!! Send the 768th frame OK!! Send the 769th frame OK!! Send the 770th frame OK!! Send the 771th frame OK!! Send the 772th frame OK!! Send the 773th frame OK!! Send the 774th frame OK!! Send the 775th frame OK!! Send the 776th frame OK!! Send the 777th frame OK!! Send the 778th frame OK!! Send the 779th frame OK!! Send the 780th frame OK!! Send the 781th frame OK!! Send the 782th frame OK!! Send the 783th frame OK!! Send the 784th frame OK!! Send the 785th frame OK!! Send the 786th frame OK!! Send the 787th frame OK!! Send the 788th frame OK!! Send the 789th frame OK!! Send the 790th frame OK!! Send the 791th frame OK!! Send the 792th frame OK!! Send the 793th frame OK!! Send the 794th frame OK!! Send the 795th frame OK!! Send the 796th frame OK!! End customer OK !! Download customer OK !! Start to download recovery ... Downloading the data ... Send start command OK !! Send the 1th frame OK!! Send the 2th frame OK!! Send the 3th frame OK!! Send the 4th frame OK!! Send the 5th frame OK!! Send the 6th frame OK!! Send the 7th frame OK!! Send the 8th frame OK!! Send the 9th frame OK!! Send the 10th frame OK!! Send the 11th frame OK!! Send the 12th frame OK!! Send the 13th frame OK!! Send the 14th frame OK!! Send the 15th frame OK!! Send the 16th frame OK!! Send the 17th frame OK!! Send the 18th frame OK!! Send the 19th frame OK!! Send the 20th frame OK!! Send the 21th frame OK!! Send the 22th frame OK!! Send the 23th frame OK!! Send the 24th frame OK!! Send the 25th frame OK!! Send the 26th frame OK!! Send the 27th frame OK!! Send the 28th frame OK!! Send the 29th frame OK!! Send the 30th frame OK!! Send the 31th frame OK!! Send the 32th frame OK!! Send the 33th frame OK!! Send the 34th frame OK!! Send the 35th frame OK!! Send the 36th frame OK!! Send the 37th frame OK!! Send the 38th frame OK!! Send the 39th frame OK!! Send the 40th frame OK!! Send the 41th frame OK!! Send the 42th frame OK!! Send the 43th frame OK!! Send the 44th frame OK!! Send the 45th frame OK!! Send the 46th frame OK!! Send the 47th frame OK!! Send the 48th frame OK!! Send the 49th frame OK!! Send the 50th frame OK!! Send the 51th frame OK!! Send the 52th frame OK!! Send the 53th frame OK!! Send the 54th frame OK!! Send the 55th frame OK!! Send the 56th frame OK!! Send the 57th frame OK!! Send the 58th frame OK!! End recovery OK !! Download recovery OK !! Reset OK!! Download finished!!!! Waitting for unplug the device .... Download cost 158.70 s Last edited by MyGSM World; 09-25-2017 at 16:00. Reason: Wrap Code Added | |
07-24-2017, 08:10 | #7 (permalink) |
Junior Member Join Date: Nov 2006
Member: 392182 Status: Offline Thanks Meter: 4 | Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! [PDL] : Setting FlashMode ... [PDLBoot] : Sending First PDL ... [PDLBoot] : First Boot Ok! [PDLBoot] : Sending Second PDL ... [PDLBoot] : Second Boot Ok! Boot Finished! Handshake with FL Ok! [PDLFlash] : Sending All Images [PDLFlash] : Processing now BOOTLOADER File : Intex_Aqua_R4+_V05_Indian_SER_20150731_0918_rda_to tal.bin Flashing ... [PDLFlash] : Flash region done! [PDLFlash] : Processing now BOOT File : Intex_Aqua_R4+_V05_Indian_SER_20150731_0918_rda_to tal.bin Flashing ... [PDLFlash] : ERROR! PartitionFinalize rejected! Check FlashFile and connection! Flashing Done! Reboot Phone Elapsed: 00:00:14 Reconnect Power/Cable! what is problm sir help me |
