07-01-2008, 11:54 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 305905 Status: Offline Thanks Meter: 9 | my pin finder,,has no power out put coz ill try to read via tester its postive and negative out put of the pinfinder but it cant read nothin,,or no voltage out put,, can you explain better where the capasitor to put [[[additional capacitor (f.e. 2200 mF) to Adapter power line]]] |
07-01-2008, 12:00 | #2 (permalink) |
Member: 305905 Status: Offline Thanks Meter: 9 | if i short where the diode is place,,it is harmful to my box or not????? i have no electronic back ground so kindly give some opinion before i start using my newly arrive pin finder,, before anything go wrong,, ijust simply dont understand this,,im confuse about it,,kindly explain more tia additional capacitor (f.e. 2200 mF) to Adapter power line i just want you to know that my finder is detected by software,,just the problem is no power out put pls help infinity team |
07-01-2008, 14:13 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, How about to read text BEFORE picture that you have posted ? Code: ● In some cases it may be that voltage from PC USB port or from Unibox is not enough to make phone Powered-On. It's need to check Unibox output RJ45 pin-1 (or Adapter Input pin-8) voltage with multimeter and be sure that voltage is about +5v. If voltage is less than 5v it's need to open Unibox and replace (or just short) output diode according to picture below (depends on Unibox type): |
07-02-2008, 00:23 | #4 (permalink) |
Member: 305905 Status: Offline Thanks Meter: 9 | yes sir..my infinity tool box has an 5 volts out put from pin 1 and 8,,the problem is thers no voltage out put at pin finder,,but it can search by dongle manager,, my infinity toll box is the one with 2 rj45 out put,, |
help me in my pin finder | petro_312 | Infinity-Box | 1 | 04-05-2009 19:27 |
Can't reg my pin finder box? | The Repair Shop | Infinity-Box | 2 | 01-29-2009 16:37 |
problem with my pin finder | tshibano | Infinity-Box | 1 | 07-17-2008 22:43 |
I can't upgrade my pin finder !!!!!!!!!!! | tahernike | Infinity-Box | 2 | 05-06-2008 18:15 |
Help my Nokia 8800 has no power | danlee | Nokia Hardware & Hardware Repair | 1 | 08-29-2006 19:16 |
