Old 12-12-2009, 11:04   #1 (permalink)
Member: 267789
Thanks Meter: 5
my way touch
help me after flash phone death
COM197 [VCP1] selected
module v2.99
Device: MyWay-Touch
Checking data, wait...
Action: write NAND flash
read mode: 01
write: Firmware
MyWay-Touch_MEGA4_MLAB_PCB04_GPRS_MT6228_S02.MAUI_07A_W0 7_28_MP_V22_F2_2009-03-05_En_Fr_De_Nl.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
source data: page only
rom info protocol ver: 04
ver. sw 1: MEGA4_MLAB_PCB04_GPRS_MT6228_S02.MAUI_07A_W07_28_M P_V22_F2.BIN
ver. sw 2: MAUI.07A.W07.28.MP.V22.F2, 00000000
code offset: 00000000
ffs offset/size: 02000000/06000000
id-page2 area is found, ROM3 extracted
nfi area detection finished: Ok
Boot ...
19200 fixed
Connecting, wait...
Initializing [6228:8A02:8A02]...
CPU: MT6228
chip: 0031:ACDC:0101
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
version: 3.02
cpu-id: 07
loader: 3.0840.00.00
NAND id: AD79A500
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 2000
external ram: 00000000
finalize connection...
done
load emi configuration...
apply emi configuration...
ram size: 02000000
emi configuration done
NOR: 0000:000000000000 [00000000]
NAND: 00AD:007900A50000 [08400000]
NOR chip is not installed
Initialize Done
Set baud ...
921600
Set baud Done
Identification ...
ram test...
pass 1...
pass 2...
pass 3...
pass 4...
done
reading bootloader structure area (00010000 bytes)...
detecting bootloader structure (chip)...
warning: id-page1 area is invalid
nfi area detection finished: failed
detecting bootloader structure (source file)...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
startup code area #1 check...
startup code area #1 fixed
Identification Done
Write ...
00006000 bytes sent
write core area 1 of 3...
00416000 bytes sent
write core area 2 of 3...
00E40000 bytes sent
write core area 3 of 3...
error: code: A500000BF1
error: code: 5A
error: code: A57FBF7DFB
error: code: F7EDDBB76F
error: code: DFBF7DFB07
error: code: 0D1A3468D0
error: code: A04183060D
error: code: 1A3468D0A0
error: code: 828100050A
error: code: 1428504082
error: code: 0004152900
error: code: 4282010904
error: code: 2200480000
error: code: 0000000000
error: code: 0000000015
error: code: 00A2000001
error: code: 0022005000
error: code: 0100000000
error: code:
error: block/offset: 00000000/00000000
error: can't write nand core
Write Fail
Finished, time used: 441 sec
Remove/Install battery now !
The Following User Says Thank You to facoly For This Useful Post:
Old 12-12-2009, 11:52   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
@facoly
1. try to use ChineseMiracle v3.02
2. What was with phone before flash ? Is it was good working or damaged phone ?
Old 12-13-2009, 15:20   #3 (permalink)
Member: 267789
Thanks Meter: 5
it was to unlock I do not know the old fashioned way version
Old 12-20-2009, 15:42   #4 (permalink)
Member: 130995
Hello,
1. download and install latest ChineseMiracle module v3.03 (it was uploaded in support area today).
2. select model MT6228 NAND
3. flash phone with MyWay firmware again
Please, let us know about results.
Old 04-25-2010, 18:22   #5 (permalink)
Member: 476075
Sonork: na
Thanks Meter: 40
which cable use for myway touch.
Old 04-25-2010, 18:24   #6 (permalink)
Member: 1043909
Thanks Meter: 60,921
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
RJ45 connector pinout:
Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum
The Following User Says Thank You to YellowBoss For This Useful Post:
My-Way Touch Unlock problem rose4u86 Infinity-Box 10 02-20-2010 08:44
my way touche can't unlock mscomp Infinity-Box 9 12-05-2009 22:00
Plz help me to config Tomtom in My HTC Touch diamond isurues GPS devices , Navigators & Maps 1 08-31-2008 02:31
my way and a cheap and simple way to repair hwk clone bassmc Twisterflasher 6 04-26-2007 08:45
Which model is my One Touch 535? killoque Alcatel & TCL Old Models 1 01-10-2004 12:58
Page generated in 0.18210 seconds with 9 queries
