Old 11-09-2009, 23:44   #1 (permalink)
mscomp's Avatar
Member: 266158
Sonork: 131654654654
Thanks Meter: 198
my way touche can't unlock
pinout with pinfinder
software version: 1.19
cable type: 1x18 (L18B)
platform: MT: MT6205, MT6217-MT6228, MT6230
searching adapter at COM3...
adapter found, version: 2000
pins: 18, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
19200 fixed
19200 fixed
CPU: MT6228
result: Rx:6 Tx:7
time required: 51 sec
Trying to Power-On...
Power On !
unlock
COM3 [VCP0] selected
module v2.85
Action: read codes
unlock method: read codes
Model: MyWay-Touch
Checking data, wait...
19200 autodetect
Initializing [6228:8A02:8A02]...
CPU: MT6228
chip: 0031:0796:0101
status: FF
Connecting at 19200, wait...
warning: wrong packet cs
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 129 sec
Remove/Install battery now !
Old 11-10-2009, 01:36   #2 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
pins: 18, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
19200 fixed
19200 fixed
19200 fixed
CPU: MT6228
result: Rx:6 Tx:7
Power On !
unlock
module v2.85
Action: read codes
Model: MyWay-Touch
19200 autodetect
CPU: MT6228
status: FF
this phone is 100% supported by infinity box,i had done many of them,so keep pressed power button until (release power on) message appear in the main software also use power supply not the batterie for stable connection because u use pin finder
luck
Old 11-10-2009, 13:48   #3 (permalink)
mscomp's Avatar
Member: 266158
Thanks Meter: 198
module v2.85
Action: read codes
Model: MyWay-Touch
19200 autodetect
CPU: MT6228
status: FF
Release Power button now !
Phone detected, wait...
Hardware: MT6228,E02
Date: 2004.07.02
Version: 1.0
Version: MAUI.07A.W07.28.MP.V22.F2
Version: EZIO28_07A_HW
44 byte(s) read
imei: 35302003017860
connection Ok
157 byte(s) read
166 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 0000
Finished, time used: 17 sec
but when i put sim card it said code NP
Old 11-10-2009, 18:23   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Try to make "smart fast" unlock instead of "read codes".
Old 11-10-2009, 21:27   #5 (permalink)
mscomp's Avatar
Member: 266158
Thanks Meter: 198
ok phone un locked thanks InfinitySupport
this 3 days i cant entre to support area why you can expain or i have a prob in my net ???
Old 11-10-2009, 22:51   #6 (permalink)
Member: 130995
Hello,
There is no problems with support area.
Did you tried to use different support area mirrors ?
What is the results ?
Old 11-11-2009, 08:56   #7 (permalink)
mscomp's Avatar
Member: 266158
Thanks Meter: 198
yes all i can entre main and 1 et 2
Old 11-11-2009, 10:02   #8 (permalink)
Member: 130995
Hello,
Sorry, I did not understand well.
Are you able to enter in support area now or all support area not available for you ?
Old 12-05-2009, 18:32   #9 (permalink)
Member: 173417
Thanks Meter: 12
what cable you use?
or can i have the pinout ?
Old 12-05-2009, 22:00   #10 (permalink)
Member: 130995
Originally Posted by moache View Post
what cable you use?
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Can't unlock HTC Mega (HTC Touch 2)!!! nandger MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker 5 10-13-2011 13:25
my way touch facoly Infinity-Box 5 04-25-2010 18:24
My-Way Touch Unlock problem rose4u86 Infinity-Box 10 02-20-2010 08:44
my v56 vodafone can't unlock????? rzmadjid2 SagMaster Team OLD Products 0 12-20-2006 01:05
still can't unlock HD1 (one touch club) koax Alcatel & TCL Old Models 0 01-24-2003 15:34
Page generated in 0.24750 seconds with 9 queries
