11-20-2008, 03:11 | #1 (permalink) |
Freak Poster Join Date: Jun 2000 Location: In front of pc
Member: 1585 Status: Offline Thanks Meter: 15 | my220v...EBI_IH_290607_1125 290607_1125 EBI_IH not supported? This fw version is not yet supported? I tried to unlock this phone then suddenly it got an error that says "unknown firmware, read flash and send to support". Now the phone is dead. The three backup eeprom files were written back but still dead. In the support page, there is no repair file for this fw. Pls.help.. |
11-20-2008, 03:23 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As you can see from operation log it was done no any changes in phone memory during operation. As a result I can say: phone can not be damaged if software detected new version, so just charge phone battery and phone will be "alive". |
11-20-2008, 03:30 | #3 (permalink) |
Member: 1585 Status: Offline Thanks Meter: 15 | Here's the log: ==== log opened: [11/19/2008 3:07:16 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.51 S/N: 0FDF:0110 Wait... Current model: Sagem-my220v Ready ==== log opened: [11/19/2008 3:08:42 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.51 S/N: 0FDF:0110 Wait... Current model: Sagem-my220v Ready COM44 ready COM44 [Serial2] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-152725.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-152728.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-152734.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area repair write error [00452800]... Ok repair write error [00452800]... error: write failed[00450000] Write Failed Finished, Remove/Install battery now ! Time used: 61 sec COM44 [Serial2] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... Connecting Failed Finished, Remove/Install battery now ! Time used: 37 sec COM44 [Serial2] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-153028.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-153030.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-153035.B1E.bin reading additional data... done backup critical area Done Check memory... error: unknown firmware, read flash and send to support ! Check memory Failed Finished, Remove/Install battery now ! Time used: 47 sec COM44 [Serial2] selected Device: Sagem-my220v Checking data, wait... Action: unlock restore Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! error: wrong boot answer #1: 000038 Release Power button now Boot Failed Finished, Remove/Install battery now ! Time used: 46 sec COM44 [Serial2] selected Device: Sagem-my220v Checking data, wait... Action: unlock restore Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-153336.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-153339.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-153345.B1E.bin reading additional data... done backup critical area Done Check memory... error: unknown firmware, read flash and send to support ! Check memory Failed Finished, Remove/Install battery now ! Time used: 50 sec COM44 [Serial2] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-153541.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-153544.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-153549.B1E.bin reading additional data... done backup critical area Done Check memory... error: unknown firmware, read flash and send to support ! Check memory Failed Finished, Remove/Install battery now ! Time used: 52 sec ==== log opened: [11/19/2008 4:02:53 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.51 S/N: 0FDF:0110 Wait... Current model: Sagem-my220v Ready ==== log opened: [11/19/2008 4:08:31 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.53 S/N: 0FDF:0110 error: Dongle firmware[0110] is out of date (too old) ! Download latest "DongleManager" from support area: http://www.infinity-box.biz and upgrade dongle firmware. ==== log opened: [11/19/2008 4:11:54 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.53 S/N: 0FDF:0111 Wait... Device: Sagem-my220v Ready ==== log: [11/19/2008 4:12:13 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-161235.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-161238.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-161244.B1E.bin reading additional data... done backup critical area Done Check memory... error: unknown firmware, read flash and send to support ! Check memory Failed Finished, Remove/Install battery now ! Time used: 52 sec ==== log: [11/19/2008 4:13:35 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... error: can't run main loader: FF Finished, Remove/Install battery now ! Time used: 18 sec WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/19/2008 4:14:20 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... error: can't run main loader: FF Finished, Remove/Install battery now ! Time used: 39 sec WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/19/2008 4:15:14 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... error: can't run preloader: E8F0 middle part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Failed Finished, Remove/Install battery now ! Time used: 41 sec WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/19/2008 4:16:16 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... error: can't run preloader: 0100 middle part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Failed Finished, Remove/Install battery now ! Time used: 15 sec Loading file v.02... Sagem-my220v_eeprom-complete_20081119-152734.B1E.bin loaded ==== log: [11/19/2008 4:18:26 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-161845.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-161849.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-161854.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 35 sec Loading file v.02... Sagem-my220v_eeprom-sec_20081119-152728.B1E.bin loaded ==== log: [11/19/2008 4:19:56 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-162015.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-162018.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-162023.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 30 sec Loading file v.02... Sagem-my220v_eeprom-sta_20081119-152725.B1E.bin loaded ==== log: [11/19/2008 4:21:13 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... error: can't run main loader: CB Finished, Remove/Install battery now ! Time used: 8 sec ==== log: [11/19/2008 4:22:08 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-162228.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-162232.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-162237.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 32 sec WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/19/2008 4:23:17 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-162338.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-162341.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-162347.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Write Done Finished, Remove/Install battery now ! Time used: 30 sec Loading file v.02... Sagem-my220v_eeprom-complete_20081119-152734.B1E.bin loaded ==== log: [11/19/2008 4:28:35 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-162901.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-162904.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-162910.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 42 sec ==== log: [11/19/2008 4:30:36 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: unlock restore Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... error: can't run main loader: FD Finished, Remove/Install battery now ! Time used: 13 sec ==== log: [11/19/2008 4:31:02 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: unlock restore Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-163121.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-163127.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-163133.B1E.bin reading additional data... done backup critical area Done Check memory... error: unknown firmware, read flash and send to support ! Check memory Failed Finished, Remove/Install battery now ! Time used: 54 sec ==== log: [11/19/2008 4:32:45 PM] ==== COM44 [Serial2] selected module v1.53 Device: Sagem-my220v Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20081119-163305.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20081119-163311.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20081119-163317.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Program Files\InfinityBox\Pana01\read\Sagem-my220v_flash_20081119-163954.B1X.bin completed Finished, Remove/Install battery now ! Time used: 445 sec I will mail the read flash file... |
11-20-2008, 03:53 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, compare your first message with your log. What was the reason to make incorrect explanation about real situation ? If backup file was readed after write failure we can not use this flash backup to create repair file. Is it possible to read full flash from the same good working phone ? |
11-20-2008, 09:09 | #7 (permalink) |
Member: 1585 Status: Offline Thanks Meter: 15 | Problem solved! Sagem my220v-EBI_IH_290607_1125 290607_1125 EBI_IH = Vodafone-v226_EBI_IH_280607_1844_lock_area_original.B1E.bin They are the same. The phone now is alive but still locked. I tried to unlock it but it won't accept the unlock code. So i tried to unlock it again using S**dd and its done. |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
i have tyr 5130 is not support [ Its SL3, is not supported !!! ] | ABDULLAHI MUHD | Cyclonebox | 1 | 01-25-2010 19:57 |
Again not supported phone KF311,but supported says it is supported for flashing | Hady_e02@yahoo | Z3X-Team Products | 1 | 09-11-2009 09:52 |
@ infiinty Support...Infinity Box supports or does not support Unlock alc. v607 v570 | residentdenuevo | Infinity-Box | 0 | 08-15-2009 01:48 |
7310 not support ?? i tried but not support. :( | kaholukkk | Universalbox | 1 | 03-13-2009 14:34 |
