12-24-2008, 03:26 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: APPLE DR.
Member: 463037 Status: Offline Thanks Meter: 135 | my220x keypad not work done by infinity just write new eerom from the support...100% the phone is working... COM10 [VCP0] selected Device: Sagem-my220x Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\my 220x\Sagem-my220x_eeprom-sta_20081224-100504.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\my 220x\Sagem-my220x_eeprom-sec_20081224-100518.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\my 220x\Sagem-my220x_eeprom-complete_20081224-100529.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 54 sec |
The Following 2 Users Say Thank You to wilnert For This Useful Post: |
12-24-2008, 19:35 | #4 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
kg195 auto off auto keypad buton working, keypad not working .by guljee | guljee786 | LG Hardware Repair | 4 | 01-23-2011 18:41 |
6500s keypad not working done by via jumper | mark_07 | Nokia Base Band 5 ( BB-5 ) | 11 | 03-17-2010 10:56 |
k310i keypad not working and joy stick not working how can i make jumper | shani72 | Sony Ericsson Hardware Repair | 1 | 12-09-2009 16:58 |
2600c keypad not work up key,downkey,optionskey,cencelkey not work after change ic. | lavkey | Nokia Hardware & Hardware Repair | 1 | 08-08-2008 16:52 |
V6 unlock done keypad not working | chris2007 | Smart-Clip | 5 | 07-12-2008 08:36 |
