12-08-2009, 10:35 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | New phone ajanta a-3000 pl add this>>> HEARE IS PIN CONNECTION;- Code: software version: 1.20 cable type: 1x20 (L20A) platform: MT: MT6205, MT6217-MT6235 searching adapter at COM6... adapter found, version: 2000 pins: 20, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6225 result: Rx:8 Tx:7 time required: 68 sec Trying to Power-On... Power On ! saved: AJANTA_A-3000 HEARE IS OK SET READED LOG;- Code: COM6 [VCP0] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0A03:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.1BC22A6B.[M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8.BIN_E26831B7].rpl ==================== New firmware detected (v.3.02, database date: unknown): M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 1BC22A6B rom info protocol ver: 04 ver. sw 1: M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8.BIN ver. sw 2: M200A_V1_8, B73168E2 code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8__fullflash... file saved: C:\Program Files\InfinityBox\ChineseMiracle\M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8__fullflash_20091208-145045.B0M ajanta a-3000 file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M200A_PCB01_GPRS_MT6225_S00.M200A_V1_8__system_log_1BC22A6B_E26831B7_20091208-145123.B0X.bin Finished, time used: 712 sec Remove/Install battery now ! HEARE IS UPLOAD FULL OK SET FILE LINK:- |
The Following 2 Users Say Thank You to debmobile For This Useful Post: |
12-08-2009, 11:06 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | you should post in chinese miracle section !! and that is HERE https://forum.gsmhosting.com/vbb/f425/ BR Faisal_Computer |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
Heare is new model ajanta a2100 ditels | debmobile | Infinity-Box | 7 | 12-28-2009 21:18 |
New phone fortune f32 pl add this>>> | debmobile | Infinity-Box | 1 | 12-20-2009 20:27 |
New phone fortune f16 pl add this>>> | debmobile | Infinity-Box | 6 | 12-20-2009 20:14 |
New model simoco sm233 pl add this | debmobile | Infinity-Box | 2 | 12-20-2009 20:01 |
Heare is new model ajanta a5000 new firmware | debmobile | Infinity-Box | 3 | 12-19-2009 08:58 |
