01-15-2011, 05:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pilipinas
Member: 757159 Status: Offline Thanks Meter: 467 | Myphone Ms28 Format Error? module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:BBDF:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.26, database date: 13.01.2011): TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E01C_PH ILIPPINES_PINOY_V1_5.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E01C_PH ILIPPINES_PINOY_V1_5.BIN project-id: E01C_PHILIPPINES_PINOY_V1_5, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/001F0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 error: no any expected answer error: flash erase error: 00E00000 error: no any expected answer error: erase #E2 error: format ffs failed Finalization Fail Finished, time used: 58 sec Remove/Install battery now ! Is this supported by infinity? |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
