Old 09-15-2008, 11:22   #1 (permalink)
FullFLASHgSMPH's Avatar
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
myphonE T11 FORMAT ERROR
COM10 [VSerial0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:A8C4:6733
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 97 sec
Remove/Install battery now !
please check already flash error
Old 09-15-2008, 11:24   #2 (permalink)
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
READING
PLEASE ADD FILE:
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
230400
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.61AF53B1.[YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN_083D3FE8].rpl
identification#1 detection finished
device-id: 61AF53B1
identification#1 protocol ver: 04
ver. sw1: YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN
ver. sw2: YZ06_C003.6226.L10.F03.D40.C1.U1.V1.50, 17C0C2F7
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: flash[YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN]...
Old 09-16-2008, 22:19   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Try to make "complete" format instead of "safe".
Do not forget to make full flash backup before format !
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-17-2008, 06:09   #4 (permalink)
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
same sir...........
"complete" format instead of "safe".COM3 [VSerial0] selected
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
device-id: 61AF53B1
ffs chip: 00
reading: eeprom[YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN]...
warning: wrong data size at 0x00E20400, retry...
error: too many retries during read operation
Probably errors exist during flash read operation.
Do you want to repeat read operation ?
error: no any expected answer
operation canceled by user
error: no any expected answer: wrong answer after chip id request
error: no any expected answer: wrong answer after chip cfi request
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Fail
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_61AF53B1_YZ06_FLB_PCB01_GPRS_MT6227_S01. BIN_083D3FE8_20080917-120749.B0X.bin
Finished, time used: 237 sec
Old 09-17-2008, 14:20   #5 (permalink)
Member: 130995
Hello,
You must use high-quality FTDI-based box/cable (f.e. Infinity-Box Unibox) instead of cheap and buggy chinese cables.
Why you have used low quality cables in your work ?
Old 09-18-2008, 02:11   #6 (permalink)
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
pardon..cant get point
ty
Old 09-18-2008, 07:11   #7 (permalink)
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
COM13 [VCP2] selected
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
device-id: 61AF53B1
ffs chip: 00
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_61AF53B1_YZ06_FLB_PCB01_GPRS_MT6227_S01. BIN_083D3FE8_20080918-131013.B0X.bin
Finished, time used: 146 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 09-18-2008, 07:43   #8 (permalink)
Member: 572549
Thanks Meter: 172
can you share the back up files?........pls i need it urgent.......
Old 09-18-2008, 08:58   #9 (permalink)
Member: 130995
@FullFLASHgSMPH
As I can see after replacing the cable process was ok
@T0T0
It will be better to send flash backup to [email protected] so we will be able to upload more files in support area.
Old 09-18-2008, 08:59   #10 (permalink)
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
yes keep infinity
done thanls
Old 09-18-2008, 22:54   #11 (permalink)
Member: 130995
Hello,
One more advice how to fix problems with bad Prolific cables: install good working drivers.
Here is link (see bottom of page): http://www.atm-box.com/index.php?id=utilities
myphone s21 format error ACID_ICED SpiderMan 7 05-23-2009 07:37
myPhone t11 shut off!DONE" with PADFINDER & MULTIBOX LITE" liferocks_85 Multi-box LITE 1 10-24-2008 08:51
MyPhone T11 format ok and pinout here keaelite Infinity-Box 1 09-27-2008 08:23
Myphone T11 backup fullflash needed T0T0 Infinity-Box 3 09-12-2008 17:42
MyPhone T11??? jhay_12 Infinity-Box 7 07-01-2008 11:50
Page generated in 0.41854 seconds with 8 queries
