11-20-2008, 07:48 | #1 (permalink) |
Freak Poster Join Date: Jul 2004
Member: 73455 Status: Offline Thanks Meter: 23 | MyPhone T22 Lock code done with infinity detecting pinouts on pinfinder then user code reset on chinese miracle COM25 [VCP0] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "user code" unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 high speed boot enabled CPU: MT6226MA detected chip: 0031:F141:3774 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E223C2200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 230400 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E223C2200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb number of flash chip/regions detected: 01/01 total flash region size: 02000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: X6_PCB02_GPRS_MT6226M_S01.X6+_FLP_06_12_V2_3-TN-MP-5B-QN.BIN ver. sw2: X6+_FLP.06.12.V2.3-TN-MP-5B-QN, 00000000 ffs offset/size: 01C00000/003F0000 detecting security area (code #2)... .................................................. .................................................. ............................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 01C00000 flash: 01227E223C2200:29EA0000000000 checking area[00000000]: 00000000-01FFFFFF... eeprom/ffs found near: 01C00000 detecting eeprom/ffs size... eeprom/ffs size: 00400000 ffs chip: 00 eeprom/ffs area: 00000000:01C00000-01FFFFFF detecting ffs structure pass 1... ................... detect standard fat location pass #1... .................................................. .................................................. ............ detect extended fat location pass #1... .................................................. .. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[X6_PCB02_GPRS_MT6226M_S01.X6+_FLP_06_12_V2_3-TN-MP-5B-QN.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[X6_PCB02_GPRS_MT6226M_S01.X6+_FLP_06_12_V2_3-TN-MP-5B-QN.BIN]_20081120-144017.B0E.bin flash: 01227E223C2200:29EA0000000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... Special operation Done Write... flash: 01227E223C2200:29EA0000000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 444 sec Remove/Install battery now ! |
The Following User Says Thank You to topnoyze For This Useful Post: |
11-20-2008, 08:05 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
>>> MYPhone T22 DUO lock code done and PINOUT HERE <<< | keaelite | Infinity-Box | 10 | 06-22-2009 19:22 |
m120 phone lock code done with error... | shawgsm | SPT BOX | 8 | 04-04-2009 02:05 |
Q380-B Lock Code Done By Infinity!! [Pinout's Inside] | UnLoCkit | Infinity-Box | 0 | 01-30-2009 08:50 |
Alcatel S210 Lock Code Done By Infinity | UnLoCkit | Infinity-Box | 1 | 08-29-2008 12:15 |
>>> N82 lock code done by infinity and pinout here <<< | keaelite | Infinity-Box | 1 | 07-05-2008 11:26 |
