Old 10-04-2007, 14:55   #1 (permalink)
Member: 202611
Thanks Meter: 51
N 73 Dku2 Connector Flashed 2day
COM1 [Serial0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detect device parameters finished
structure: 2nd [enhanced] (or higher) generation
identification data Ok
identification data backup saved: id.039E9299.[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN_B9C8841A].rpl
New firmware detected: SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN
- make "Read detailed information, ask/rpl" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification detection finished
device-id: 039E9299
protocol ver: 04
ver. sw1: SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN
ver. sw2: V2.0628.0.0.1
ffs offset/size: 00E00000/00200000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area: 00000000:00E00000-00FFFFFF
reading [eeprom[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN]]...
file saved: backup_eeprom[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN]_20071004-163229.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: backup_system_log_039E9299_SZMI26_05C_SET_PCB01_GP RS_MT6226_S01.V2_0628_0_0_1.BIN_B9C8841A_20071004-163244.B0X.bin
Finished, time used: 243 sec
Remove/Install battery now !
I Successful formating n73 restarting problem well 2day
Old 10-08-2007, 14:36   #2 (permalink)
wisam_wa's Avatar
Member: 103945
Sonork: 100.112828
Thanks Meter: 353
plz send piout dor this model
Old 10-08-2007, 14:38   #3 (permalink)
AYMAN SHAMAYLH's Avatar
Member: 146798
Sonork: 100.1576177
Thanks Meter: 24
for restart problem only format phone
no need full flash
Old 10-08-2007, 18:09   #4 (permalink)
Member: 592748
Thanks Meter: 4
just formate in complicte mathode.>>>>>><<<<<<
Old 10-08-2007, 20:21   #5 (permalink)
Member: 242240
pin out for n73
Old 10-09-2007, 09:44   #6 (permalink)
Member: 202611
Thanks Meter: 51
pin out for n73
this is correct pin out tested by me work 100% perfect every one should use this
Old 10-10-2007, 21:42   #7 (permalink)
.::koolfriend4u::.'s Avatar
Member: 200145
Sonork: 100.1596786
Thanks Meter: 677
s its xactly the rght pin out..
thnks
Old 12-17-2007, 14:55   #8 (permalink)
ambt's Avatar
Member: 57196
Thanks Meter: 9
thanx for help
b,r
ambt
Old 12-17-2007, 15:03   #9 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
but there is one more N73 china Copy with having service light with front camera.. any one know the pinout for this as normal pinouts not working for this.......
Old 12-18-2007, 02:39   #10 (permalink)
banalven1's Avatar
Member: 202941
Thanks Meter: 84
yes i also have 1 n73 like tis,can any1 can share the pinout~~
thk~`
Old 12-18-2007, 07:45   #11 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,290
thk~`
Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts),
bottom connectors and different pinouts we recommend you to include the next info:
1. detailed description of model
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, check the next detailed description how to get pinout for your model:
use "Cable Selector": "Cable selector" at your service...
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
N-73 afterh full flash, not booting.. amit123 Nokia Hardware & Hardware Repair 1 05-03-2009 17:35
N 73 dead after flashing gsm_farooq Nokia Base Band 5 ( BB-5 ) 7 01-13-2009 14:04
N73-1 Dku2 connector pinout mrhoussem Infinity-Box 2 07-27-2008 09:55
Can i use DKU2 to flash Nokia 3250 n_bennyhk MT-BOX 5 04-07-2006 13:25
Page generated in 0.64142 seconds with 9 queries
