09-19-2007, 13:42 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | n 95 2 sim repaired thx to infinity tested by TuniServ look here /* * * * * * * * * * * *\ 1 2 3 4 5 6 7 8 9 10 10 12 connect gnd to conector 6 rx 7 tx ------------------------------------------- COM8 [VCP0] selected Device: Autodetect 6205-6227,6228 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.73319D6E.[N618_PCB01_GPRS_MT6227_S01.1.BIN_51959CA1].rpl identification detection finished device-id: 73319D6E protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.1.BIN ver. sw2: N618.1 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [eeprom[N618_PCB01_GPRS_MT6227_S01.1.BIN]]... file saved: backup_eeprom[N618_PCB01_GPRS_MT6227_S01.1.BIN]_20070919-142723.B0E.bin flash: EC257E25082501:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: EC257E25082501:29EA0000000000 Write Done file saved: backup_system_log_73319D6E_N618_PCB01_GPRS_MT6227_ S01.1.BIN_51959CA1_20070919-142739.B0X.bin Finished, time used: 337 sec Remove/Install battery now ! |
09-19-2007, 15:38 | #10 (permalink) |
Insane Poster Join Date: Apr 2007
Member: 498516 Status: Offline Thanks Meter: 4 | n95 repair. hi thanks to infinity team,i have done the phone about a month ago. Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.41 S/N: 0Dxx:01xxx Wait... Current device: Autodetect Done COM4 [VCP0] selected Device: Autodetect Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.E3A29E57.[N618_PCB01_GPRS_MT6227_S01.1.BIN_BF2835F9].rpl identification detection finished device-id: E3A29E57 protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.1.BIN ver. sw2: N618.1 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF reading [flash[N618_PCB01_GPRS_MT6227_S01.1.BIN]]... file saved: backup_flash[N618_PCB01_GPRS_MT6227_S01.1.BIN]_20070827-134956.B0M.bin file saved: backup_system_log_E3A29E57_N618_PCB01_GPRS_MT6227_ S01.1.BIN_BF2835F9_20070827-135028.B0X.bin Finished, time used: 1664 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default ! Do you want to continue ? COM4 [VCP0] selected Device: Autodetect Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.E3A29E57.[N618_PCB01_GPRS_MT6227_S01.1.BIN_BF2835F9].rpl identification detection finished device-id: E3A29E57 protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.1.BIN ver. sw2: N618.1 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF reading [eeprom[N618_PCB01_GPRS_MT6227_S01.1.BIN]]... file saved: backup_eeprom[N618_PCB01_GPRS_MT6227_S01.1.BIN]_20070827-135638.B0E.bin flash: EC257E25082501:29EA0000000000 Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: EC257E25082501:29EA0000000000 Write Done file saved: backup_system_log_E3A29E57_N618_PCB01_GPRS_MT6227_ S01.1.BIN_BF2835F9_20070827-135657.B0X.bin Finished, time used: 244 sec Remove/Install battery now ! all credit goes to the great infinity team. w.b.r matrix123 |
09-19-2007, 20:58 | #12 (permalink) |
Insane Poster Join Date: Aug 2006
Member: 327501 Status: Offline Thanks Meter: 0 | Detailed instructionL "ChineseMiracle": how to repair "reboot with SIM card" 1. make full flash backup for emergency case (use 921000 speed for fast operation) 2. select "safe format method" 3. make "format ffs" 4. remove/install battery 5. press and hold phone "Power" button during 30-40 sec to make phone powered-on if phone Ok go to step-6 if phone not Ok, go to step 2 and select "complete format method" 6. restore original imei |
N 95 2 sim pinout necessary | serkan45 | Infinity-Box | 10 | 03-14-2008 17:05 |
n 95 2 sim reboot | az cells | Infinity-Box | 4 | 02-18-2008 20:05 |
