07-15-2010, 05:54 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Daet Cam., Norte Philippines
Member: 824202 Status: Offline Sonork: zyx_lexus Thanks Meter: 5 | N5160 restart now dead! History: restarting when sim is inserted, according to the owner she dropped it. I tried safe format no luck full format no luck format whole flash chip now dead! Logs: Code: Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] Chinese Miracle v3.07 S/N: 2CB1:0116 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [7/15/2010 9:36:43 AM] ==== COM5 [VCP0] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4903:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.07, database date: 16.01.2010): N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12.BIN project-id: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size [01]: 00E20000/001E0000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E20000 standard ffs/eeprom offset confirmed: 00E20000 detecting ffs/eeprom size... ffs/eeprom size: 001E0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E20000-00FFFFFF detecting ffs/eeprom structure pass 1... ....................... detect standard ffs/eeprom location pass #1... ............................................ detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12.BIN detecting firmware build... ................................................................ ................................................................ done detecting product-id... ................................................................ done detecting languages... ...................................... language parameters detected detected languages: En Ru Fr Tr Farsi Ar sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Finished, time used: 1 min 51 sec Remove/Install battery now ! Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: BHZ006_V2.0 Software version: MAUI.GEMINI.W08.12" Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 354800030322137 imei-2: 354800030322137 imei-3: 354800030322137 Finished, time used: 3 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [7/15/2010 9:39:31 AM] ==== COM5 [VCP0] selected module v3.07 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4903:0004 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12 Version: BHZ006_V2.0 detecting structure #2... 5 11 done 67 byte(s) read imei: 35480003032213 connection Ok building list... done items to clear: 156 warning: wrong packet cs warning: wrong packet cs items cleared: 156 of 156 building list... done items remains: 0 Finished, time used: 38 sec Remove/Install battery now ! Check your country laws before use this option ! In some countries this operation may be prohibited ! You must think serious before continue ! Do you understand above text well and want to continue ? Action: "repair imei" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 354357000048021 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 354800030322130 verification Ok Finished, time used: 3 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [7/15/2010 9:43:17 AM] ==== COM5 [VCP0] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4903:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.07, database date: 16.01.2010): N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12.BIN project-id: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size [01]: 00E20000/001E0000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E20000 standard ffs/eeprom offset confirmed: 00E20000 detecting ffs/eeprom size... ffs/eeprom size: 001E0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E20000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12__ffs... warning: wrong data size at 0x00E6B400, retry... read error recovered file saved: C:\Program Files\InfinityBox\ChineseMiracle\N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12__ffs_20100715-094549.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 2 min 50 sec Remove/Install battery now ! UploadMB.com |
07-27-2010, 04:55 | #6 (permalink) | |
Member: 824202 Status: Offline Sonork: zyx_lexus Thanks Meter: 5 | Quote:
No luck means it doesn't work never powers on the phone. here the logs: hope you can help me or send me a good or working file maybe the firmware file is already damaged. TIA! ==== [7/26/2010 1:20:08 PM] ==== COM5 [VCP0] selected module v3.15 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12__fullflash_20100715-115308.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4903:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer : wrong answer after chip id request flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.15, database date: 06.06.2010): N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12.BIN project-id: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size [01]: 00E20000/001E0000 rom info structure: 2nd [standard] generation TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 18 sec Remove/Install battery now ! | |
Plss help , I tried to change imei with wintesla on 5110 5.22 , now ... | Nec | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-11-2000 23:26 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
