04-04-2008, 14:56 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | N72 Sub IMEI Error... after formatting N72, imei is damaged... 13579024680.. after reflashing eeprom main imei is corrected... but sub imei is broken still... 13579024680 pls help me.. |
05-09-2008, 12:36 | #4 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
sub imei not fixing... pls check the log... Code: COM11 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 new imei: 355555555555550 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... . detection phase #2... ........... detect device identification#1 finished identification#1 protocol ver: 02 ver. sw1: E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN ver. sw2: E558AGENT_F1.01.5, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00380000 flash: 01227E221A2201:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 00380000 detecting eeprom/ffs size... eeprom/ffs size: 00080000 ffs chip: 00 eeprom/ffs area: 00000000:00380000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN]_20080509-143120.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data... 2 step(s) required to finalize Patch required data Done Special operation... Special operation Done Write... flash: 01227E221A2201:18E59F00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 98 sec Remove/Install battery now ! | |
05-09-2008, 15:15 | #5 (permalink) | |
supporters i m waiting still.. | |
05-10-2008, 07:34 | #8 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | and sub imei is in the 6205 cpu... and phone no power on with "Power On/6205" point.. phone has two point on the pcb for power on.. "power on 6226" and "power on 6205" |
05-10-2008, 07:42 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | As I can see from attached log, it was no problems with imei writing. Anyway, you can try to make this: 1. make "format ffs" for 2nd CPU (now 2nd imei is default) 2. power-on phone, wait several minutes, check 2nd imei 3. power-off phone via "power" key 4. write 2nd imei again now check phone |
05-10-2008, 07:51 | #10 (permalink) | |
05-10-2008, 07:53 | #11 (permalink) | |
If imei is damaged this can't affect to sim-card detection by phone | |
05-10-2008, 08:12 | #12 (permalink) | |
not changed anything... still imei is 135790...... | |
05-10-2008, 08:48 | #14 (permalink) | |
ffs:complete Code: COM11 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... . detection phase #2... ........... detect device identification#1 finished identification#1 protocol ver: 02 ver. sw1: E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN ver. sw2: E558AGENT_F1.01.5, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00380000 flash: 01227E221A2201:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 00380000 detecting eeprom/ffs size... eeprom/ffs size: 00080000 ffs chip: 00 eeprom/ffs area: 00000000:00380000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN]_20080510-103359.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E221A2201:18E59F00000000 Finalization Done Finished, time used: 51 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Code: COM11 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 new imei: 330192350159758 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... . detection phase #2... ........... detect device identification#1 finished identification#1 protocol ver: 02 ver. sw1: E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN ver. sw2: E558AGENT_F1.01.5, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00380000 flash: 01227E221A2201:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00380000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00080000 ffs chip: 00 eeprom/ffs area: 00000000:00380000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN]_20080510-104315.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "imei repair" procedure again If imei can't be detected: 1. make "complete" ffs format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei repair" procedure again If imei can't be detected: read flash and send to support: [email protected] Patch required data Fail Finished, time used: 44 sec Remove/Install battery now ! | |
05-10-2008, 08:50 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, follow the next procedure now: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "imei repair" procedure again If imei can't be detected: 1. make "complete" ffs format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei repair" procedure again |
1208 Imei error | marhabamobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-29-2010 13:20 |
How To Trace Nokia N72 By IMEI......... | Ankit Verma | Off Topic Zone | 4 | 11-06-2009 20:40 |
AnyCool T828i PDA Sub IMEI..? | LoveLess | Infinity-Box | 2 | 08-28-2008 19:44 |
