Old 02-11-2009, 08:54   #1 (permalink)
Member: 101615
Thanks Meter: 7
N73-1 pinout
COM3 [VCP0] selected
module v2.73
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:BD41:41E4
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: V2.0628.0.0.1
Version: NokiaN73(11)
detecting structure #2...
done
60 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 216
items cleared: 197 of 216
building list...
done
items remains: 1
Finished, time used: 151 sec
Remove/Install battery now !
The Following User Says Thank You to GEORGIA For This Useful Post:
Old 02-11-2009, 22:25   #2 (permalink)
Member: 148515
Thanks Meter: 14,897
hello!
thank you for sharing this with us!!!
Old 02-13-2009, 19:24   #3 (permalink)
Member: 110518
Thanks Meter: 15
i need help to connect cable L14E with N73 with power to batt. connector becuse when i connect the battry connector make red led off,
thanx in advance.
Old 02-13-2009, 20:01   #4 (permalink)
Member: 148515
thanx in advance.
hello!
you must be used wrong polarity
double check this
Old 02-14-2009, 15:22   #5 (permalink)
Member: 110518
Thanks Meter: 15
hello!
double check this
However, when used polar quenched lamp with red-polar I put in the right place.
Positive in the positive and negative in the negative. But to no avail.
pinfinder it can't read the rx and tx. if i chose from list from (InfinityBox PinFinder) program and run (ChineseMiracle) no response.
plz help me how i can connect it.
Old 02-14-2009, 22:05   #6 (permalink)
Member: 148515
hello!
can you check if your phone is MT62xx MCU based
Old 02-16-2009, 13:12   #7 (permalink)
Member: 110518
Thanks Meter: 15
hello!
yes it is sir, and i have today N72 i don't know what mcu typ. and pinfinder can not chick it.
Old 02-16-2009, 19:12   #8 (permalink)
Member: 148515
hello!
you can do this without disassembling phone by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software (mt62xx based)
Old 02-17-2009, 13:31   #9 (permalink)
Member: 110518
Thanks Meter: 15
[QUOTE=InfinityHelp;4162621]hello!
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software (mt62xx based)[/QUOTE
Thank you very much, Mr.
I noted at the poles connect any type of phone on the pinfinder extinguished, the lamp
Even when connected with pinfinder on output2, the Nokia 3110 i noted the red lamp turn off. Is the problem of Pinfinder?
Old 02-19-2009, 13:09   #10 (permalink)
Member: 110518
Thanks Meter: 15
Hello, sir
Please Sir
Please help me in the operation of the pin finder it whether or not the failure.
Old 02-19-2009, 13:12   #11 (permalink)
Member: 110518
Thanks Meter: 15
Hello, sir
Please Sir
Old 02-19-2009, 22:43   #12 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 209
Hello,
Please, check PinFinder according to "SelfTest" chapter from PinFinder manual.
What is the results ?
N73s spreadtrum pinout overdose Infinity-Box 1 06-03-2008 08:50
N73s spreadtrum pinout ?? overdose SpiderMan 0 06-02-2008 22:17
n73 2sim pinout MaHmUt1982 Infinity-Box 1 05-30-2008 08:10
N73-1 Pinout please rajumobile Infinity-Box 9 01-23-2008 02:53
NEX MINI and N73 CABLE PINOUT Nasmi Infinity-Box 2 12-17-2007 23:20
Page generated in 0.38233 seconds with 9 queries
