Old 10-11-2007, 13:00   #1 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
Thumbs up ZT6668 reset problem -solve 100% ok
@ infinity team
ZTC ZT6668 2sim new firmware detected due to formatte ..
and succesfull with formatte by infinity box
here is log
COM6 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detect device parameters finished
structure: 2nd [enhanced] (or higher) generation
identification data Ok
identification data backup saved: id.59FB35CC.[E553_X9PA_E553_GPRS_MT6226_S01.E553_X8PA_01_1.BIN_ 4AEEF559].rpl
New firmware detected: E553_X9PA_E553_GPRS_MT6226_S01.E553_X8PA_01_1.BIN
- make "Read detailed information, ask/rpl" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification detection finished
device-id: 59FB35CC
protocol ver: 04
ver. sw1: E553_X9PA_E553_GPRS_MT6226_S01.E553_X8PA_01_1.BIN
ver. sw2: E553_X8PA.01.1
ffs offset/size: 00800000/001FF000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area: 00000000:00E00000-00FFFFFF
reading [eeprom[E553_X9PA_E553_GPRS_MT6226_S01.E553_X8PA_01_1.BIN]]...
file saved: backup_eeprom[E553_X9PA_E553_GPRS_MT6226_S01.E553_X8PA_01_1.BIN]_20071011-164404.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: backup_system_log_59FB35CC_E553_X9PA_E553_GPRS_MT6 226_S01.E553_X8PA_01_1.BIN_4AEEF559_20071011-164421.B0X.bin
Finished, time used: 322 sec
Remove/Install battery now !
i read fullflash of this firmware ..
thnx to infinity box
Amit Tank
Old 10-11-2007, 14:17   #2 (permalink)
Member: 310155
Thanks Meter: 1,313
thanks for ur test resualt.........................................
Old 10-11-2007, 14:54   #3 (permalink)
Member: 202611
Thanks Meter: 51
i have one zt6618 pin connector 1x12 i need pinout ur own what pin connector pls
Old 10-12-2007, 19:51   #4 (permalink)
SRNOURI's Avatar
Member: 29870
Thanks Meter: 24
Dear Amit Tank
Can you explain about your phone such as connector type or pinout of that.?
BR.
Old 10-13-2007, 06:59   #5 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
hi
pin out is mention on pcb ,, Rx A Tx A and Gnd print on pcb .. use this and is work , same pin out in N95..
Amit Tank
Vertu Constellation reset user code 100% OK! Burebista Nokia Base Band 5 ( BB-5 ) 19 05-02-2019 18:39
E61 SIM Problem Solved 100% OK! yogesh06 Nokia Hardware & Hardware Repair 19 05-10-2011 00:47
c 115 / 117 charging problem solve 100% work. maheshsaiganesh Motorola Hardware Repair 22 02-11-2011 11:17
Bleu 670z restart problem solved 100% OK jayeshoswal05 Infinity-Box 3 08-02-2009 14:21
Nokia 2100 Missed Calls problem solved 100% Tanvir Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 12-01-2003 21:26
Page generated in 0.18081 seconds with 9 queries
