02-03-2010, 14:25 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | NKTEL K700 6235 chip durring complete formating error COM3 [VCP0] selected module v3.08 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND warning: NOR flash chip is not installed NAND flash chip: S_DA_NAND_UNSUPPORTED_DEV_ID error: flash id: 0098:00D100900015 NAND_UNKNOWN internal RAM: S_DONE size: 00010000 external RAM: S_DA_DEVICE_NOT_FOUND done Set baudrate (921600)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 44 sec Remove/Install battery now ! |
02-03-2010, 16:20 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, it's phone with new (not supported) hardware type: Code: NAND flash chip: S_DA_NAND_UNSUPPORTED_DEV_ID error: flash id: 0098:00D100900015 NAND_UNKNOWN |
02-09-2010, 00:40 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, If you still have this phone on hands. please, try to use this new software: http://www.infinity-box.com/download...e_v3.09_v1.rar Waiting for your results. |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
02-09-2010, 13:38 | #5 (permalink) | |
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Quote:
COM3 [VCP0] selected module v3.09 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.936.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND warning: NOR flash chip is not installed NAND flash chip: S_DONE flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT flash size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00010000 external RAM: S_DA_DEVICE_NOT_FOUND done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7320B_V1.0.4 detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: B7320B_BOOTLOADER_V005_MT6235B_7320B_V1_0_4.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: B7320B_PCB01_GPRS_MT6235B_S01.7320B_V1_0_4.BIN project-id: 7320B_V1.0.4, 6D2DABFF code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ===> done Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 1 min 9 sec Remove/Install battery now ! | |
The Following User Says Thank You to rameez_gsm For This Useful Post: |
02-10-2010, 17:50 | #7 (permalink) | |
nktel k700 starting pro.......... | jamaletw | Infinity-Box | 3 | 11-26-2010 20:22 |
MC922 complete format | dgtulga | Infineon C16X M51 & ARM7 M52 BASED | 3 | 07-01-2001 08:55 |
COMPLETE FORMAT on Sagem MC922 4.1M | Pym4o | Infineon C16X M51 & ARM7 M52 BASED | 0 | 05-16-2001 18:23 |
COMPLETE FORMAT | Banj-alike | Infineon C16X M51 & ARM7 M52 BASED | 0 | 12-29-2000 20:29 |
Need help for Complete Format MC920 | softneed | Infineon C16X M51 & ARM7 M52 BASED | 5 | 12-09-2000 21:54 |
