N73 Invalid Sim I got an N73 Chinese Phone but when I tried to read codes ALL SECURITIES ARE OFF yet it displays an INVALID SIM when sim is inserted. What would be the probs... Imei serial is :135xxxxxxx Will changing Imei solve the problem? Here is the logs from Unlocking Unlocking Method : STANDARD http://i67.photobucket.com/albums/h3...s/Snap1-18.jpg LOGS Quote:
OOOOPPPPSSS Got it! |
How about instruction from screenshot ? Please, follow instruction and send required files |
How do you have solve your problem Salam |
your imei is bad!! hey bro you imei is wrong !!! you must to rewrite your imei for the original one!! make it and request:D |
It's ok now i have found it anyway thanks kamel928 Salam |
i have exat same problem with pls sulotion big thx sim kart not deteckt and restart with sim i have formated safe have flashed exat with same phone bekup amd i have change imei etc ..no result have same problem i can call without sim n.p .. have any sulotion pls b.r senkron24 log : COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:5C2E:9322 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.C6081DFE.[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN_2743684E].rpl identification#1 detection finished device-id: C6081DFE identification#1 protocol ver: 04 ver. sw1: SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN ver. sw2: V2.0628.0.0.1 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _C6081DFE_SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_ 0628_0_0_1.BIN_2743684E_20080124-162045.B0X.bin Finished, time used: 131 sec Remove/Install battery now ! |
