04-14-2009, 14:43 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | n73 not power on here is the logo COM7 [Serial2] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1D41364 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:FFFFFF00000000 Finalization Done Finished, time used: 230 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
04-14-2009, 20:03 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @shahabuddin if you have original full flash backup write it back and then make "format ffs" in "safe" mode. if you do not have original backup you must check operation.log file, see original firmware version there and flash phone with similar firmware from support area. |
04-15-2009, 11:44 | #4 (permalink) | |
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | Quote:
backup or operation log. i m n trouble plz help infinity | |
04-15-2009, 11:54 | #5 (permalink) | |
04-17-2009, 23:17 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you must open with notepad operation.log file which is located in Chinese Miracle folder. scrool it from up from end and find First operation with this phone. there you will see Original software version. |
N73 not power on with battery solution | .:Tanveer.: | Nokia Hardware & Hardware Repair | 0 | 01-24-2010 12:22 |
N73 not power on [SOLVED] | ismabdi | Cyclonebox | 1 | 12-22-2009 07:13 |
N73 with software cable on but with battry not power on | zohaib555 | Nokia Hardware & Hardware Repair | 2 | 09-13-2009 20:21 |
N73 Not Power On - The History Of Phone Given - Please Help Me | rajeevpchandran | Nokia Hardware & Hardware Repair | 9 | 03-21-2009 02:56 |
