N73 RH-13 pinout needed Hi to all. I have N73 bad copy phone. N68_v1.3 jn board name on board no any pins to connect connector - 2x6 2xCpu I found RxTx for mt6226, but can't find for second 6205 CPu... :( pins for 1st cpu - /1____6\ |7___12| 2 - Rx 7 - gnd 8 - Tx Plz, any help for found 2nd cpu pinouts... |
hello! take multimeter and measure voltages on rest of pins. find those which are 2,7-2,9 volts- they wqill be CPU_b pinouts better if you will do this on powered On phone and inserted to both sim card slots SIM cards |
I tryed, but not luck. I remove second cpu - and check to connector from pins - no any signal. connected to pins directly and problem solved, thanks :) |
can you share with us picture of test points for second pinout? |
