08-13-2007, 09:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | N77 ChineseMiracle supported no need any update here is log not like another tools who anonuse support but no working solution. WARNING ! Settings will be cleared, user data erased, Imei set to default ! Do you want to continue ? COM8 [VCP0] selected Device: Autodetect Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [standard] (or higher) generation protocol ver: 04 ver. sw1: F421M02_PCB01_GPRS_MT6226_S01.M_RF4230404_M01001_V 1_0_0_1M0608.BIN ver. sw2: M.RF4230404.M01001.V1.0.0.1M0608 ffs offset/size: 00F00000/00100000 detecting eeprom area in 1 chip(s)... flash: 89881500010001:89881500000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00F00000 Detected eeprom address is non-standard: 00F00000 If you are not sure that detected address is correct: 1. press "NO" right now 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom address confirmed by user detecting eeprom size... eeprom size: 00100000 eeprom chip: 00 eeprom area detected[00000000]: 00F00000-00FFFFFF reading [eeprom[F421M02_PCB01_GPRS_MT6226_S01.M_RF4230404_M01001_V 1_0_0_1M0608.BIN]]... file saved: backup_eeprom[F421M02_PCB01_GPRS_MT6226_S01.M_RF4230404_M01001_V 1_0_0_1M0608.BIN]_20070812-191901.B0E.bin flash: 89881500010001:89881500000000 Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 89881500010001:89881500000000 Write Done Finished, time used: 59 sec Remove/Install battery now ! flash file will be in support area asap .. |
08-28-2007, 11:38 | #3 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | one more boss. black berry clone.. skywork name on it.. Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.E3C19E67.[SKYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN_8F20795E].rpl identification detection finished device-id: E3C19E67 protocol ver: 04 ver. sw1: SKYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN ver. sw2: MAUI.05C.W06.16.MP.V7 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: 98004900000002:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF reading [eeprom[SKYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN]]... file saved: backup_eeprom[SKYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN]_20070824-213137.B0E.bin flash: 98004900000002:29EA0000000000 Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 98004900000002:29EA0000000000 Write Done file saved: backup_system_log_E3C19E67_SKYWORTH26_05C_PCB01_GP RS_MT6226_S01.MAUI_05C_W06_16_MP_V7.BIN_8F20795E_2 0070824-213148.B0X.bin Finished, time used: 78 sec |
No Need any activation or any box..... | UnlockByLogs | All UnlockByLogs Server | 3 | 12-16-2009 07:28 |
Long time no see any updates | nasagih | SpiderMan | 1 | 08-15-2009 23:57 |
new tested soft fix pm120 bb5 no need any box | RamSon83 | Nokia Base Band 5 ( BB-5 ) | 22 | 07-03-2009 11:40 |
C417 samsung unlock by code no need any soft. | kmaxmax | UST Pro II | 1 | 05-22-2009 11:24 |
new s.e. logger with all new updates no need any box. | RahulGSM | Main Sales Section | 0 | 08-19-2005 07:39 |
