Old 08-03-2008, 11:40   #1 (permalink)
UnLoCkit's Avatar
Member: 486305
Thanks Meter: 465
N77 mini china phone dead done by Infinity
N77 MINI CHINA PHONE DEAD DONE BY INFINITY!!
Problem; Dead
PINOUT'S;
TRY TO FORMAT; BUT EROR!!
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:F2C1:4B62
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: A9EA80F098E59F:A9EA8000000000
number of flash chip/regions detected: 00/01
Unknown or damaged flash chip, operation aborted.
     Fault reasons:
1. damaged flash chip: replace or resolder/reball flash chip
2. damaged hardware: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 122 sec
Remove/Install battery now !
SOLUTION; REFLOW CPU THEN FORMAT FFS AGAIN
FORMAT FFS;
click the image to inlarge
 LOGS;
Action: reset
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.B1F5F324.[T6226_05C_PCB01_GPRS_MT6226_S01.N200_U1_SD_OPEN_V5_6_2.BIN_9C2732E6].rpl
New firmware detected:
- make "Read full flash" operation
- send "backup_system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: B1F5F324
identification#1 protocol ver: 04
ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.N200_U1_SD_OPEN_V5_6_2.BIN
ver. sw2: N200_U1_SD_OPEN_V5.6.2, 19CDD863
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.N200_U1_SD_OPEN_V5_6_2.BIN]]...
warning: wrong data size at 0x00E0F000, retry...
read error recovered
warning: wrong cs at 0x00F13800, retry...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.N200_U1_SD_OPEN_V5_6_2.BIN]_20080803-115742.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_B1F5F324_T6226_05C_PCB01_GPRS_MT6226_S01.N200_U1_SD_OPEN_V5_6_2.BIN_9C2732E6_20080803-115806.B0X.bin
Finished, time used: 431 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
CHANGE IMEI;
The Following 2 Users Say Thank You to UnLoCkit For This Useful Post:
Old 08-03-2008, 22:02   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 08-04-2008, 00:32   #3 (permalink)
Member: 739232
Thanks Meter: 41
n77 connector is damage
i need pin out in PCb
http://img99.imageshack.us/img99/1315/28939525zl2.jpg
Old 08-05-2008, 23:34   #4 (permalink)
Member: 739232
Thanks Meter: 41
http:///vbb/showthread.php?t=575103
Iphone A9 Dead Done by Infinity!![ With PINOUT"S] UnLoCkit Infinity-Box 1 11-14-2008 19:38
Mp4 Mini China Phone Dead Done by Infinity!! UnLoCkit Infinity-Box 2 10-09-2008 22:23
POCKET PDA (F1) China Phone Dead Done By Infinity!! UnLoCkit Infinity-Box 3 10-09-2008 22:08
VG207 phone lock done by infinity jakoy Infinity-Box 2 06-21-2008 09:21
6500 [China] New Pinouts Done by INFINITY UnLoCkit Infinity-Box 2 06-16-2008 20:55
Page generated in 0.30122 seconds with 8 queries
