11-20-2008, 04:09 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Land of Promise
Member: 659309 Status: Offline Thanks Meter: 121 | Coral C200 Digicel Locked/ unlocked success by infinity box.. i just want to share this problem Coral C200 after unlocked it always asking simlock code... il try to enter the code 12345678 acording with the logs but it doesn't work.. Action taken.. I just read some solution here's the procedure.. 1.using infinity box select model zte 225 then flash it with main and language pack... before you do that make backup first especially with the eeprom.. 2.start to flash main and language pack and also the backup eeprom then flash until complete flash.. flash file zte 225 here.. Main => http://www.megaupload.com/?d=RCS204VK Lang => http://www.megaupload.com/?d=CHC9BY3N COM4 [VCP0] selected Device: ZTE-225, Vodafone-225 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00EC:22A0 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-sta_20081112-223538.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-sec_20081112-223541.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-complete_20081112-223548.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 40 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 pinout here.. job done.. make your own risk gudluck kingskie... |
The Following 2 Users Say Thank You to kingskie For This Useful Post: |
11-20-2008, 04:55 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Coral C200 Digisel locked/Unlocked Done.. | kingskie | Infinity-Box | 1 | 11-13-2008 16:42 |
sagem my 220x unlock ok by infinity box i love infinity box | genci titi 2002 | Infinity-Box | 2 | 11-11-2008 12:02 |
<< LG KG 271 Unlocked successfully By Infinity >> | zeel_zeel | Infinity-Box | 1 | 08-07-2008 12:53 |
LG KE970 unlock success by infinity | jakoy | Infinity-Box | 3 | 07-21-2008 16:05 |
J100 Unlock Successfully By Infinity. | debmobile | Infinity-Box | 1 | 07-05-2008 09:58 |
