03-20-2008, 12:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: NEW DELHI, INDIA Age: 50
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | K3288 firmware needed! support site has this file = CM_K3288_3_PCB01_GPRS_MT6226_S01[1].00.2__16m_En_Cn.B0M.bin |
03-20-2008, 22:50 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, unfortunately you are right, we dont have this flash file. but are you sure that you need to flash? did you try to solve your problem by formating FFS ? (safe & complete) |
03-21-2008, 08:06 | #3 (permalink) |
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | COM32 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:361A:54A5 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9743BE08.[K3288_9_PCB01_GPRS_MT6226_S01.00.1.BIN_EBED3B20].rpl New firmware detected: K3288_9_PCB01_GPRS_MT6226_S01.00.1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 9743BE08 identification#1 protocol ver: 04 ver. sw1: K3288_9_PCB01_GPRS_MT6226_S01.00.1.BIN ver. sw2: K3288_9.00.1, DFC41214 ffs offset/size: 00800000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _9743BE08_K3288_9_PCB01_GPRS_MT6226_S01.00.1.BIN_E BED3B20_20080321-123326.B0X.bin Finished, time used: 168 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Still Dead ! |
03-21-2008, 08:48 | #4 (permalink) |
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | whil doing FFS SAFE ! it powers on and stays at main screen ! after done FFS SAFE ! when i put battrey and power on ! it still remains dead! also tried power on till 1 minute !! COM32 selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:361A:54A5 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: K3288_3.00.2_MT6226 Version: HW2.0 detecting structure #2... done 60 byte(s) read imei: 35362746002581 connection Ok building list... done items to clear: 209 warning: wrong packet cs warning: wrong packet cs 206 of 209 items cleared building list... done 3 items remains Finished, time used: 58 sec Remove/Install battery now ! |
03-21-2008, 10:23 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello did you make backup as program asked? please send it to us with backup_system_log_..." file to support: [email protected] looks you have damaged firmware, need to find same working phone to read out working backup |
03-28-2008, 13:41 | #7 (permalink) |
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | yes sent ! waiting !!!! if any one have same model contact me ! CM_K3288_9_PCB01_GPRS_MT6226_S01[1].00.2__16m_En_Cn.B0M.bin |
L6 firmware needed urgently needed | masterprinters | Motorola P2k | 5 | 06-16-2009 14:31 |
X700 REV 0.1 FIRMWARE NEEDED. after REV 0.2 firmware WHITE DISPLAY | *Diablo* | SWIFT Platform | 0 | 12-28-2006 11:05 |
8210 5.28 Firmware needed | Accura | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-24-2001 01:17 |
6210 Firmware Needs Upgrading | techi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-04-2001 17:20 |
