04-15-2008, 03:50 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Stop WAR on GSM Business
Member: 328416 Status: Offline Thanks Meter: 42 | N88 Restarting after Format same problem.. [IMG]file:///C:/DOCUME%7E1/MJ/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/MJ/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG] |
04-16-2008, 00:00 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make read detailed information and find suitable flash file http://forum.gsmhosting.com/vbb/showthread.php?t=499453 |
04-17-2008, 03:15 | #5 (permalink) |
Member: 328416 Status: Offline Thanks Meter: 42 | I try those step but i'm failed to get version of its SW... COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: 01227E22022201:FFFFFF00000000 checking area[00000000]: 00000000-007FFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size error: chip layout not detected error: chip layout not detected Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 59 sec Remove/Install battery now ! advise please |
04-23-2008, 11:32 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if you know how to use pinfinder and have found pinouts with it before- then only one reason can be- pinout is not presented in system connector. i would advice to search for pinout in available test points. you can find them by measuring voltage on them pins with voltage 2,7-2,9 volts will be data lines |
cect v180 restarting problem but after ffs same problem | shripalkawdia | Infinity-Box | 9 | 05-09-2009 02:06 |
6600 restart after software same | shani72 | Nokia Hardware & Hardware Repair | 1 | 08-21-2008 06:46 |
E740 restarting after format FFS | nishaon | UST Pro II | 1 | 08-13-2008 15:05 |
restarts after format | ..:: Mobile Clinic™ ::.. | MC-Tool | 4 | 07-29-2008 13:34 |
n97s still restart after format with infinity | alamgarh | Infinity-Box | 5 | 05-10-2008 08:12 |
