N8820 Flash File Needed Here is its Complete Format Log. COM4 [VCP0] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:79EA:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22212201:42EA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22212201:42EA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22212201:42EA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22212201:42EA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22212201:42EA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22212201:42EA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 it's time to stop: 420000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.30, database date: 16.05.2011): H659GX_NT_ML_PCB01_GPRS_MT6223P_S00.H659GX_NT_ML_V 1_0_2.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: H659GX_NT_ML_PCB01_GPRS_MT6223P_S00.H659GX_NT_ML_V 1_0_2.BIN project-id: H659GX_NT_ML_V1.0.2, 00000000 code offset: 00000000 ffs offset/size [01]: 00DC0000/00240000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00DC0000 flash: 01227E22212201:42EA0000000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00E00000 Detected ffs/eeprom address is non-standard: 00E00000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22212201:42EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22212201:42EA0000000000 Finalization Done Finished, time used: 1 min 6 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Another person need this file http://forum.gsmhosting.com/vbb/6186707-post679.html |
hello! must be very rare or new firmware. unfortunately we dont have it in our collection. you can try to search for same working phone on local market. read out full backup and use it for flashing your faulty phone. also i can convert to infinity format BIN file, if you find it. by the way, did you try to solve your problem without flashing, just by format FFS/IMEI restoring? |
