Old 05-21-2011, 14:48   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 889
N8820 Flash File Needed
Here is its Complete Format Log.
COM4 [VCP0] selected
module v3.30
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:79EA:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22212201:42EA0000000000
flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 420000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
New firmware found (v.3.30, database date: 16.05.2011):
H659GX_NT_ML_PCB01_GPRS_MT6223P_S00.H659GX_NT_ML_V 1_0_2.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 04
sw version: H659GX_NT_ML_PCB01_GPRS_MT6223P_S00.H659GX_NT_ML_V 1_0_2.BIN
project-id: H659GX_NT_ML_V1.0.2, 00000000
code offset: 00000000
ffs offset/size [01]: 00DC0000/00240000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00DC0000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00E00000
Detected ffs/eeprom address is non-standard: 00E00000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 1 min 6 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Another person need this file
*spider-man flash files and pinouts "request here"*
Old 05-22-2011, 22:00   #2 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
must be very rare or new firmware.
unfortunately we dont have it in our collection.
you can try to search for same working phone on local market.
read out full backup and use it for flashing your faulty phone.
also i can convert to infinity format BIN file, if you find it.
by the way, did you try to solve your problem without flashing, just by format FFS/IMEI restoring?
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 17:24
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware Repair 2 07-23-2013 03:41
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 12:35
Page generated in 0.29042 seconds with 8 queries
