Old 06-04-2007, 16:20   #1 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
n91 china dead
hi i receive n91 for this pb :
when i receive a message i'm not founded in the inbox i tried to flash but phone dead
n91 RM-42 IC : 661U-RM42 FCC ID:PYARM-42
COM1 selected
Device: Autodetect
Checking data, wait...
Action: Flash write
Write: Firmware
Skip: Customization
Skip: Language Pack
Skip: Eeprom
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6219:8A01]...
Release Power button now !
Boot Done
Initialize...
detecting chip[00] in region[00]...
flash: 01227E22202200
flash: 29EA0000000000
flash: AMD/Fujitsu std [0008x002000 00FEx010000 0008x002000] 16Mb
total number of flash chip detected: 01
Initialize Done
Set baud...
115200
Set baud Done
Check space...
operation mode: Complete detection mode
device parameters autodetection in progress..
total flash region size: 01000000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom area
Do you want to use standard eeprom address[00E00000] ?
standard eeprom address selected by user
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area detected[00000000]: 00E00000-00FFFFFF
detect device identification, method #1...
detection phase #1...
detection phase #2...
Err: device identification detection failed, no any information found
reading [eeprom]...
file saved: backup_eeprom_20070604-153402.B0E.bin
Check space Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
Area: Firmware
Write: Firmware
Write Done
Finished, time used: 1470 sec
Remove/Install battery now !
phone now dead.
any solution plz to revive this phone ?
Old 06-04-2007, 16:49   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
1. check phone hardware
2. use other firmware for flashing
3. read this:
D:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_repair_dead_Chinese_phone_MT6226_MT6227 _etc_En.htm
Old 06-04-2007, 17:14   #3 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
hi
thx for replay but i found only one firmware in the support for n91.
Old 06-04-2007, 19:50   #4 (permalink)
Member: 130995
try other firmware files or find other the same good phone for flash reading
Old 06-05-2007, 10:05   #5 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
for example N91i ?? or any file
Old 06-05-2007, 10:17   #6 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
and this my log text :
COM1 selected
Device: Autodetect
advanced flash detection active
Action: read/check detailed information
Boot...
19200
Connecting, wait...
Boot Done
Initialize...
flash: Amd, AMD/Fujitsu std [0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Check space...
operation mode: Fast detection mode
eeprom chip: 00
warning: identification information not found, possible reasons:
.old firmware type w/o identification
.damaged firmware
.damaged hardware
detection phase #3...
.....................error: unexpected termination/freez: 00540000
detect device parameters finished
Finished, time used: 92 sec
Old 06-05-2007, 11:46   #7 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
i flashed him with n91i flash file but always dead and i reflashed him with n91 and always dead
COM1 selected
Device: Autodetect
Action: write flash
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom
Boot...
19200
Connecting, wait...
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Check space...
eeprom found near: 00700000
Detected eeprom address is non-standard: 00700000
If you are not sure that detected address is correct:
1. press "NO" right now
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom address confirmed by user
eeprom size: 00900000
eeprom chip: 00
eeprom area detected[00000000]: 00700000-00FFFFFF
protocol version: 0004
2nd [standard] (or higher) generation model detected
version sw1: CKT26_05C_PCB01_GPRS_MT6226_S01.WOLF_LSM_112_06102 5_SS0_OV0_SP64_CTF_RU.BIN
version sw2: WOLF_LSM_112_061025_SS0_OV0_SP64_CTF_RU
reading [eeprom[CKT26_05C_PCB01_GPRS_MT6226_S01.WOLF_LSM_112_06102 5_SS0_OV0_SP64_CTF_RU.BIN]]...
file saved: backup_eeprom[CKT26_05C_PCB01_GPRS_MT6226_S01.WOLF_LSM_112_06102 5_SS0_OV0_SP64_CTF_RU.BIN]_20070605-112241.B0E.bin
Check space Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
Area: Firmware
Write: Firmware
Write Done
file saved: backup_system_log[CKT26_05C_PCB01_GPRS_MT6226_S01.WOLF_LSM_112_06102 5_SS0_OV0_SP64_CTF_RU.BIN]_20070605-114332.B0X.bin
Finished, time used: 2463 sec
Old 06-05-2007, 12:07   #8 (permalink)
ticoichip's Avatar
Member: 194302
Thanks Meter: 32
your problem here : CKT26_05C_PCB01_GPRS_MT6226_S01.WOLF_LSM_112_06102
Your phone has chip MT6219, try to find out flash file with MT6219 not MT6226
can you post picture your phone?
Old 06-07-2007, 13:11   #9 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
i flashed this phone with all flashes in the support with MT6219 but always phone dead.
Old 06-07-2007, 15:14   #10 (permalink)
Member: 130995
in this situation need to rad flash from similar phone and write into yours phone.
N91 4GB dead after flash N91 8GB flash file MUTUAL Nokia Base Band 5 ( BB-5 ) 7 03-25-2009 12:21
N91 rm43 dead by usb flashing pearsonjohnboy MT-BOX 15 06-20-2007 12:49
N91 flashing - dead phone dimon MT-BOX 22 05-15-2006 17:09
Page generated in 0.36091 seconds with 8 queries
