n95 2 sim empty flash chep dear infynity team ,I have a n95 with empty flash,I know it is need to flash ,but which file to choose i dont know help me infinity team here is a log Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:E930:4314 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 01227E22202200:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size error: chip layout not detected error: chip layout not detected Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 170 sec Remove/Install battery now ! I need your help please? |
hello! by this log i only can see that flash is erased. do you mabe have some earlyer logs with visable version? if not- better if you post here picture of phone we will try to recoginse it also post connector type and pinout. this also will be useful to recognise it |
can someone help me? i dont know wich file to use for these nokia phone http://radikal.ru/F/i028.radikal.ru/...c1018.jpg.html, http://radikal.ru/F/i024.radikal.ru/...675ca.jpg.html this is picture of these phoe ,please help me somebody??????? |
conector is 1*12 mini |
12 is gnd 6 rx 7 tx |
hello! I have done them perosnally, but dont remmeber now which version they were are... I am sure some forum member will help us |
I am waiting y ou all ................... |
have someone done these nokia?please helpm me?I tried with 3 kinds of files,but no succes... |
CM_Nokia-N95-2sim_MIKI26_05C_PCB01_GPRS_MT6226_S01.V65_16_16m_E n_Cn_Cn_Th_Es_Fr_Ru_Ar_Pt_Vn.B0M.bin try this from support U will be lucky..... |
dear my friend I tried these file ,but no result is any idea? pay attention Flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb |
what should I do I dont know,my be read flash from the same an other phone and write it to second? |
I am sure this is the Falashas N618_PCB01_GPRS_MT6227_S01_16m_En_Ru_Fr_Th_Vn_Ar_v er4.B0M.bin |
thank you bro I will try tommorow |
still waiting no file could make the phone worked .....anybody helps me? |
