Old 04-25-2008, 13:05   #1 (permalink)
Member: 342909
Thanks Meter: 6
n95 2 sim empty flash chep
dear infynity team ,I have a n95 with empty flash,I know it is need to flash ,but which file to choose i dont know help me infinity team here is a log
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:E930:4314
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:FFFFFF00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
operation terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
error: chip layout not detected
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Finished, time used: 170 sec
Remove/Install battery now !
I need your help please?
Old 04-25-2008, 15:10   #2 (permalink)
Member: 148515
Thanks Meter: 14,731
hello!
by this log i only can see that flash is erased.
do you mabe have some earlyer logs with visable version?
if not- better if you post here picture of phone
we will try to recoginse it
also post connector type and pinout. this also will be useful to recognise it
Old 04-25-2008, 15:12   #3 (permalink)
Member: 342909
Thanks Meter: 6
can someone help me? i dont know wich file to use for these nokia phone
http://radikal.ru/F/i028.radikal.ru/...c1018.jpg.html,
http://radikal.ru/F/i024.radikal.ru/...675ca.jpg.html
this is picture of these phoe ,please help me somebody???????
Old 04-25-2008, 15:16   #4 (permalink)
Member: 342909
Thanks Meter: 6
conector is 1*12 mini
Old 04-25-2008, 15:26   #5 (permalink)
Member: 342909
Thanks Meter: 6
12 is gnd 6 rx 7 tx
Old 04-25-2008, 15:49   #6 (permalink)
Member: 148515
hello!
I have done them perosnally, but dont remmeber now which version they were are...
I am sure some forum member will help us
Old 04-25-2008, 15:58   #7 (permalink)
Member: 342909
Thanks Meter: 6
I am waiting y
ou all ...................
Old 04-26-2008, 02:41   #8 (permalink)
Member: 342909
Thanks Meter: 6
have someone done these nokia?please helpm me?I tried with 3 kinds of files,but no succes...
Old 04-26-2008, 08:14   #9 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
CM_Nokia-N95-2sim_MIKI26_05C_PCB01_GPRS_MT6226_S01.V65_16_16m_E n_Cn_Cn_Th_Es_Fr_Ru_Ar_Pt_Vn.B0M.bin
try this from support
U will be lucky.....
Old 04-26-2008, 18:40   #10 (permalink)
Member: 342909
Thanks Meter: 6
dear my friend I tried these file ,but no result is any idea?
pay attention Flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Old 04-26-2008, 18:43   #11 (permalink)
Member: 342909
Thanks Meter: 6
what should I do I dont know,my be read flash from the same an other phone and write it to second?
Old 04-26-2008, 22:54   #12 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,290
Flash chip configuration is not so important.
Old 04-27-2008, 01:22   #13 (permalink)
Member: 486806
Thanks Meter: 8
I am sure this is the Falashas
N618_PCB01_GPRS_MT6227_S01_16m_En_Ru_Fr_Th_Vn_Ar_v er4.B0M.bin
Old 04-27-2008, 08:10   #14 (permalink)
Member: 342909
Thanks Meter: 6
thank you bro I will try tommorow
Old 04-29-2008, 14:26   #15 (permalink)
Member: 342909
Thanks Meter: 6
still waiting no file could make the phone worked .....anybody helps me?
n95 2-sim unsupported NOR flash chikubie SpiderMan 4 07-17-2008 14:00
n95 2-sim - unsupported nor flash type chikubie SpiderMan 1 07-01-2008 11:25
I Face Common Problem In N95 2 Sim Slider chiragsp_codes Infinity-Box 4 11-23-2007 09:43
need 2 repair n95 2-sim restart sayyedikram Infinity-Box 1 10-15-2007 11:37
how to flash china n95 2 sim? .:RAGE:. Infinity-Box 1 10-04-2007 23:30
Page generated in 0.40921 seconds with 8 queries
