Old 10-03-2007, 00:03   #1 (permalink)
Member: 240930
Thanks Meter: 16
Red face N95 2sim dead after flash!!
the program show error when write rpl(eeprom not found)
which epprom file into site support i can download ?
COM19 [Serial2] selected
Device: Autodetect 6205-6227,6228 NOR
Checking data, wait...
advanced flash detection active
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization
skip: Language Pack
write: Eeprom
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
total flash region size: 01000000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom area
Do you want to use standard eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard eeprom address selected by user
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area: 00000000:00E00000-00FFFFFF
reading [eeprom]...
file saved: backup_eeprom_20071003-022152.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
detect device identification, method #1...
detection phase #1...
detect device parameters finished
structure: 2nd [enhanced] (or higher) generation
identification data damaged
identification detection finished
Area: Firmware
Write: Firmware
Area: Eeprom
Write: Eeprom
formatting...
device-id: 5300997C
protocol ver: 04
ver. sw1: N618_PCB01_GPRS_MT6227_S01.BIN
ver. sw2: N618.1
ffs offset/size: 00E00000/00200000
warning: invalid identification, ask/rpl calculation reqired
Probably identification data damaged,
device id: 5300997C
firmware version:
N618_PCB01_GPRS_MT6227_S01.BIN_C3A0516F
RPL file must be in folder: G:\Program Files\InfinityBox\ChineseMiracle\
You can create RPL from ASK via client/server right now and press YES.
Do you want to write RPL file now ?
error: no any expected answer
error: no any expected answer: wrong answer after chip id request
error: wrong answer[C4]
error: no any expected answer: wrong answer after chip cfi request
error: can't detect chip at required chip base
error: rpl write failed
Write Done
Finished, time used: 486 sec
Remove/Install battery now !
when i use read detailed information Ask/rpl
view this error:
Action: read/check detailed information
Boot...
19200
Connecting, wait...
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device-id: 5300997C
protocol ver: 04
ver. sw2: N618.1
device id: 5300997C
firmware version:
error: wrong answer[3B]
eeprom chip: 00
detection phase #3...
error: unexpected termination/freez: 00000000
done
detecting structure pass 1...
can't detect fat name location
eeprom element #1 detection failed
error: autodetection failed
Finished, time used: 112 sec
what is problem?please help me
Old 10-03-2007, 10:07   #2 (permalink)
Member: 240930
Thanks Meter: 16
Please help me it is very important for me ...
Old 10-04-2007, 00:34   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,220
Change your cable, don't use Prolific based USB->RS232 converter but use cable based on FTDI chip (f.e. Infinity-Box or any other unibox).
Also in case of any communication errors use 115200 instead of 921600
Old 10-04-2007, 00:40   #4 (permalink)
Member: 63194
Thanks Meter: 59
i have 1 n95 2 sim 12 pin can u tell me pinouts please:
Old 10-04-2007, 00:52   #5 (permalink)
Member: 130995
Hello,
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to make detailed description of model,
attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector.
After you have this information prepared, please, check the next detailed description how to get pinout for your model:
use "Cable Selector": "Cable selector" at your service...
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
n95 8gb dead after flash gorgans Infinity-Box 4 08-04-2009 16:06
N95 Clone dead after flash and Not detected by PC tj_style Chinese Models & Cloned Phones 4 04-29-2009 12:23
n82 2sim dead after flashing with file from support patric Infinity-Box 3 04-17-2008 20:08
n95 proplem dead after flash moustafatch Infinity-Box 28 12-01-2007 21:39
Page generated in 0.27247 seconds with 8 queries
