08-11-2009, 10:51 | #1 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1059036 Status: Offline Thanks Meter: 57 | N95 8g hx695 HX695_HW.S684_SET_NS5_RU9_V3_0RTEST--090414__ffs_20090720-152227.B0E I NEED TO CHANGE LANGUAGE TO FRENSH HX695_HW.P684_AR8_V3_0JTEST--080920__Nokia-N95-8Gb-RM-159_16m_En_Ru_Fr_Ro_Pl_Tr_Farsi_Ar.B0M THIS FILES IN SUPPORT COMPATIBLE WITH PHONE OR NOT |
08-23-2009, 16:35 | #3 (permalink) |
Member: 1059036 Status: Offline Thanks Meter: 57 | i tested the files in 3 phone not work for change languige in frensh ver. sw 1: HX695_HW.S684_SET_NS5_RU9_V3_0RTEST--090325.BIN plz update in support flash files frensh languige thanks |
08-25-2009, 00:13 | #5 (permalink) |
Member: 1059036 Status: Offline Thanks Meter: 57 | i have tested this files (HX695_HW.P684_AR8_V3_0JTEST--080920__Nokia-N95-8Gb-RM-159_16m_En_Ru_Fr_Ro_Pl_Tr_Farsi_Ar.B0M) aftere flash phone dead i tested in 3 phone after flash phone white oregenal flash work perfect Code: COM4 [VCP0] selected module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware HX695_HW.S684_TU6_V3_0ITEST--080905__Nokia-N95-8Gb-RM-13_16m_En_Ru_El_Ml_Tr_Farsi.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E303:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: HX695_HW.P684_AR8_V3_0JTEST--080920.BIN ver. sw 2: P684_AR8_V3.0JTEST, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: HX695_HW.P684_AR8_V3_0JTEST--080920__ffs... file saved: D:\Program Files\InfinityBox\ChineseMiracle\HX695_HW.P684_AR8_V3_0JTEST--080920__ffs_20090823-161050.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device sec info... detection phase #1... . detect device sec info finished startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... Finalization Done Finished, time used: 1612 sec Remove/Install battery now ! Loading file v.02... HX695_HW.S684_SET_NS5_RU9_V3_0RTEST--090414__fullflash_20090720-140355.B0M.bin loaded rom info protocol ver: 04 ver. sw 1: HX695_HW.S684_SET_NS5_RU9_V3_0RTEST--090414.BIN ver. sw 2: S684_SET_NS5_RU9_V3.0RTEST, 00000000 ==== log: [23/08/2009 16:38:21] ==== COM4 [VCP0] selected module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware HX695_HW.S684_SET_NS5_RU9_V3_0RTEST--090414__fullflash_20090720-140355.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E303:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: HX695_HW.S684_TU6_V3_0ITEST--080905.BIN ver. sw 2: S684_TU6_V3.0ITEST, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: HX695_HW.S684_TU6_V3_0ITEST--080905__ffs... file saved: D:\Program Files\InfinityBox\ChineseMiracle\HX695_HW.S684_TU6_V3_0ITEST--080905__ffs_20090823-164008.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device sec info... detection phase #1... . detect device sec info finished startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware error: error# 0000FFFF error: flash write error: 004E4000:00002000 detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... Finalization Done Finished, time used: 709 sec Remove/Install battery now ! Last edited by acyl2000; 01-06-2010 at 10:17. Reason: wrap [code] |
08-26-2009, 14:40 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! sad, this means that firmware is not suitable for your phone hardware. do you have language editor tool? using it you could translate your original flash file in minutes |
12-10-2009, 19:56 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this software is sold separately from infinity box. here is more info: http://www.infinity-box.com/addon/in...langedit&lg=en price is 100usd, for payment methods please contact [email protected] |
please help cannot flash n95 8g | kadricom | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-30-2010 10:06 |
job cancel for 2 vodafone N95 8G and N81 8G | ABI-GSM | All UnlockByLogs Server | 5 | 12-25-2008 11:34 |
please add n95 8g, n81 8g and 6120 no hurry, only if possible | samuelscu | BB5BOX | 0 | 01-15-2008 18:05 |
Really need support for those phones - N95 8G, N81 8G, N76 | samuelscu | BB5BOX | 1 | 12-09-2007 15:20 |
Can N81-8g, N95-8g can be unlocked now? | samuelscu | BB5BOX | 1 | 11-22-2007 14:51 |
