Old 11-12-2008, 16:46   #1 (permalink)
Member: 772384
Thanks Meter: 40
n95 8g rm-17
dear infinity team,I have n95 8g rm-17 ,i cannot find rx,tx and gnd .I know
it was discussed many times in this forum,but where is pinouts I can not understand,in cpu only gnd and power is marked.please help me
Old 11-12-2008, 17:34   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What is bottom connector type ?
Old 11-12-2008, 18:01   #3 (permalink)
Member: 223859
Thanks Meter: 35
The cable from your phone is the same mini USB,
After connecting the telephone cable select the COM port and install the drivers (6218 Drivers USB MODEM DRIVER) Located in:
C:\Program Files\InfinityBox\Drivers\MT6218
I hope I have helped you
Old 11-12-2008, 19:27   #4 (permalink)
Member: 130995
Hello,
It is need to use RX/TX/GND cable for flashing but not USB cable.
Old 11-12-2008, 20:29   #5 (permalink)
Member: 772384
Thanks Meter: 40
yes it has usb mini like motorola cabel ,but I NEED rx tx and gnd , the phone not turns on,so by measuring I CAN NOT FIND RX AND TX ,please advice me something
Old 11-12-2008, 20:53   #6 (permalink)
Member: 130995
Hello,
Where is GND pin at connector ?
Old 11-13-2008, 08:13   #7 (permalink)
msashami's Avatar
Member: 181213
Sonork: 100.1586186
Thanks Meter: 201
have u tied with pinfinder???
Old 11-13-2008, 11:55   #8 (permalink)
Member: 783324
Thanks Meter: 15
there is no gnd in connector.
Old 11-13-2008, 15:29   #9 (permalink)
Member: 223859
Thanks Meter: 35
Excuse me by mistake, but here is the correct and pinning Log's information Phone.
COM3 [VCP2] selected
module v2.68
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:3E03:0000
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 04227E22212200:18E59F00000000
flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: MT25_06B_HW.DS100_AR5_V3_1BTEST--080320.BIN
ver. sw 2: DS100_AR5_V3.1BTEST, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Finished, time used: 60 sec
Remove/Install battery now !
Remember of THANKS
Old 11-14-2008, 11:01   #10 (permalink)
Member: 783324
Thanks Meter: 15
there is no gnd in usb port bro,I think rx and tx is inside the cpu but where? no one can help me????????
Old 11-14-2008, 20:21   #11 (permalink)
Member: 130995
Hello,
Did you tried to open phone and check it's PCB for test-points ?
Old 11-14-2008, 23:46   #12 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
hello, how can I unlock this phone N95 8G? which cable to use? phone have like mini usb cable connector... phone turn on, when I insert cable... can u help please
Old 11-15-2008, 01:02   #13 (permalink)
Member: 130995
Hello,
Just use Infinity-Box ChineseMiracle software, you will see "unlock" button in "Service" page.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 11-15-2008, 16:04   #14 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
Originally Posted by InfinitySupport View Post
Hello,
Ok, but which cable to use? Any pinout please? I search forum and I found many thread about this issue, and I am confused, this is the first chinese phone want to try... thanks
Old 11-15-2008, 20:26   #15 (permalink)
Member: 783324
Thanks Meter: 15
excuse me infiity team,I opened the phone but test points I never searched in chinese phone,is it a new method or what? I searched only rx tx ,but unfortunetly did not found them
ineed flash file n95 8g rm-164 arabic tornado2008 Infinity-Box 1 08-26-2008 21:58
need pinout for n95 8g rm-164 shawgsm Infinity-Box 3 08-19-2008 21:13
please help my N95 8g rm-17..... jake007 SpiderMan 2 05-13-2008 09:38
Page generated in 0.28796 seconds with 11 queries
