Old 04-22-2008, 13:13   #1 (permalink)
green bird's Avatar
Member: 109163
Thanks Meter: 75
mpeg4 P888i second sim call hang
first phone status on off after format and write imei phone ok, but problem first sim working very well and second sim only problem when i call phone hang. then need to remove battery. i get second board by reverse pin finding solution and try to format. all well problem still continiue. this is new version no have in support area.
this details by reverse pin detection.
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:0441:9690
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
230400
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.05FA9B7B.[MTK26_05C_B888K_ARAB_PCB01_GPRS_MT6226_S01.MAUI_05 C_W06_16.BIN_B2C2F704].rpl
New firmware detected:
- make "Read full flash" operation
- send "backup_system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 05FA9B7B
identification#1 protocol ver: 04
ver. sw1: MTK26_05C_B888K_ARAB_PCB01_GPRS_MT6226_S01.MAUI_05 C_W06_16.BIN
ver. sw2: MAUI.05C.W06.16, FB083D4D
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _05FA9B7B_MTK26_05C_B888K_ARAB_PCB01_GPRS_MT6226_S 01.MAUI_05C_W06_16.BIN_B2C2F704_20080422-120637.B0X.bin
Finished, time used: 175 sec
Remove/Install battery now !
Old 04-22-2008, 19:20   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
can you post a log of formating second MCU?
Old 04-23-2008, 12:03   #3 (permalink)
green bird's Avatar
Member: 109163
Thanks Meter: 75
format ffa safe. or full ?
COM17 [VCP3] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: MAUI.05C.W06.16
Version: MALATA26_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 35488800012025
connection Ok
building list...
done
items to clear: 172
162 of 172 items cleared
building list...
done
1 items remains
Finished, time used: 145 sec
Old 04-23-2008, 17:00   #4 (permalink)
green bird's Avatar
Member: 109163
Thanks Meter: 75
full format and writed imei by all methord. also second sim network also not showing, but if you call np its connecting
also i flashed one file CM_MPEG4-P888_MTK26_05C_B888K_ARAB_PCB01_GPRS_MT6226_S01.MA UI_05C_W06_16_16m_En_Ru_Fr_Ar.B0M but result phone hang in second sim when i make or recv a call.
Action: read information
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6226, E02
Hardware version: MALATA26_05C_HW
Software version: MAUI.05C.W06.16"
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 354888000120253
Finished, time used: 5 sec
Power off phone now !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
Action: reset
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
230400
Set baud Done
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.05FA9B7B.[MTK26_05C_B888K_ARAB_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16.BIN_C9E68EF8].rpl
device-id: 05FA9B7B
ver. sw1: MTK26_05C_B888K_ARAB_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16.BIN
ver. sw2: MAUI.05C.W06.16, 07711936
ffs chip: 00
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log_05FA9B7B_MTK26_05C_B888K_ARAB_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16.BIN_C9E68EF8_20080423-152950.B0X.bin
Finished, time used: 144 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Action: imei
Connecting, wait...
imei: 135790246811220
imei write method: mode-1
new imei: 354888000120253
imei verified Ok
Action: imei
imei write method: mode-2
19200 autodetect
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
done
60 byte(s) read
connection Ok
done
60 byte(s) read
verification...
verification done: 35488800012025
Finished, time used: 21 sec
Action: imei
imei write method: mode-3
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
230400
Set baud Done
device-id: 05FA9B7B
ffs chip: 00
reading [eeprom[MTK26_05C_B888K_ARAB_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[MTK26_05C_B888K_ARAB_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16.BIN]_20080423-154925.B0E.bin
4 step(s) required to finalize
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log_05FA9B7B_MTK26_05C_B888K_ARAB_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16.BIN_C9E68EF8_20080423-155022.B0X.bin
Finished, time used: 339 sec
Old 04-23-2008, 19:46   #5 (permalink)
Member: 148515
hello!
you have problems with SIM2- it is controlled by second MCU (MCU_b)
you show us logs only for first MCU.
find pinout for MCU_b and repeat format/imei restore
H688 TV phone second sim "emergency" calls mansi Infinity-Box 20 02-21-2011 21:50
---trend t500 dual sim second sim is not working any solution--- makkah mobile Infinity-Box 1 09-12-2008 09:26
N73 work fine with out sim but hang with sim Maiwand khan Nokia Base Band 5 ( BB-5 ) 10 07-31-2008 17:07
Urgent Need Cable for MPEG4 P888i DualSimCell Infinity-Box 17 04-23-2008 16:01
mpeg4 p888i reastart vinay_sharma Infinity-Box 2 03-14-2008 17:13
Page generated in 0.21160 seconds with 9 queries
