Old 10-07-2008, 10:37   #1 (permalink)
Member: 73455
Thanks Meter: 23
Arrow N95-8gb China after flashing no Display
good day to all, i have recieved N95-8gb china deadset when it came into my shop....so what i did, i flash it with the flash file i downloaded on support site now the phone power on but no display......
here's the logs:
COM23 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:AF12:2910
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:2CEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
230400
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2C0000EA18F01FE518F01FE518F01FE518F01FE518F01FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\Back-up eeprom\n95-8gig\eeprom_20081007-153137.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
.damaged firmware
.damaged hardware
security area#1 calculation...
done
Area: Firmware
Write: Firmware
Write Done
Finalization...
Finalization Done
Finished, time used: 1261 sec
Remove/Install battery now !
just want to ask, is it possible that wrong flash file can cause this kind of problem? which is no display? i already tried two different flash file but still thesame....
Old 10-07-2008, 10:49   #2 (permalink)
kungpaoski's Avatar
Member: 329609
Thanks Meter: 245
yup bro it is possible need to find correct flash file for the unit. You should have read flash before flashing unit with flash file from support. Coz even if unit is dead and can be detected. You can read its original fw. Then you can search in support same flash file version. Unless unit has been flashed from another shop before it came to you.
b.r.
The Following User Says Thank You to kungpaoski For This Useful Post:
Old 10-07-2008, 11:28   #3 (permalink)
Member: 73455
Thanks Meter: 23
b.r.
yes i did make backup before flashing but the firmware file name is defferent already...it saves like this..."Flash_20081007-121527.BOM.bin" so i cannot figure out what exact flashfile i shud find on support area....
Old 10-07-2008, 12:02   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You must use files with firmware name similar to version that you just flashed in phone.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-07-2008, 20:55   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
as long as phone software is corrupted- there is no chance to find out what was Original firmware.
In this case i would advice either to use one by one all firmwares from N95 (8gb) or
try to find similar phone on local market and read out what firmware it is
n95 8gb reboots after flash .:GSM International:. HWK 0 08-18-2008 18:28
nokia n95 8gb china full flash need explorercris Chinese Models & Cloned Phones 5 05-24-2008 08:48
i really need help with n95 after flash no display laythjg09 Infinity-Box 3 07-12-2007 10:55
Page generated in 0.76374 seconds with 9 queries
