06-16-2008, 04:02 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | n95 8gb china phone "HANG" repaired with PINFINITY combination pinfinder logs Code: Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe Initializing... software version: 1.10 Smart-Card S/N: alfox Smart-Card firmware version: 010F Initializing PinFinder... Initializing database... base database version: 01 user database version: 01 Initializing cable list... Initializing platforms... Loading configuration... Initialization finished searching adapter at COM6... adapter found, version: 2000 Serial No: alfox done Initializing... done Cable: 1x5 (L5A) Power On ! Power Off ! software version: 1.10 cable type: 1x5 (L5A) platform: MT6205, MT6217-MT6228, MT6230 searching adapter at COM6... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6225 result: Rx:4 Tx:3 time required: 8 sec Power On ! saved: n95_8gb_L5A_alfox Power Off ! software version: 1.10 cable type: 1x5 (L5A) platform: MT6205, MT6217-MT6228, MT6230 searching adapter at COM6... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6225 result: Rx:4 Tx:3 time required: 8 sec Power On ! Code: full format COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:2603:0009 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: MT25_06B_HW.DS100_TH4_V2_1ATEST--080320.BIN ver. sw2: DS100_TH4_V2.1ATEST, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 04227E22212200:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 04227E22212200:18E59F00000000 Finalization Done Finished, time used: 47 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
06-21-2008, 07:14 | #3 (permalink) |
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | thanks also infinity team for supporting us end users so in return i choose to share here any success stories with your gadget.more power and keep up the good work |
solution for repair dead n95 8gb after bad usb flash with jaf | Kot_Silvester | Nokia Base Band 5 ( BB-5 ) | 3 | 02-10-2009 12:57 |
SE T668 China Phone Repaired with PINFINITY COMBI | alfox | Infinity-Box | 5 | 10-24-2008 02:20 |
Leady X501 Unlocked with Pinfinity combination | alfox | Infinity-Box | 1 | 09-17-2008 13:08 |
N95 8gb china phone unknown vendor | topnoyze | Multi-box LITE | 1 | 08-20-2008 08:03 |
N95 8gb china phone dead set pls help | topnoyze | PadFinder box | 1 | 08-12-2008 07:52 |
