Old 05-28-2008, 06:03   #1 (permalink)
jhepoy_org's Avatar
Member: 247410
Thanks Meter: 161
<< N95 8GB Tested Pin-out >>
Device: Autodetect 6205-6227 NOR
Done
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
COM5 [VCP2] selected
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031B14:B282
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.FFA46EA6.[T6226_05C_PCB01_GPRS_MT6226_S01.A10_EFATRISPIGM_V0 122C.BIN_EF3FD442].rpl
identification#1 detection finished
device-id: FFA46EA6
identification#1 protocol ver: 04
ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.A10_EFATRISPIGM_V0 122C.BIN
ver. sw2: A10_EFATRISPIGM_V0122C, BD2BC010
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _FFA46EA6_T6226_05C_PCB01_GPRS_MT6226_S01.A10_EFAT RISPIGM_V0122C.BIN_EF3FD442_20080526-174445.B0X.bin
Finished, time used: 135 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Action: imei
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Software version: A10_EFATRISPIGM_V012
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
new imei: 350448088888885
imei verified Ok
Finished, time used: 6 sec
Power off phone now !
The Following 2 Users Say Thank You to jhepoy_org For This Useful Post:
Old 05-28-2008, 07:12   #2 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
thanks for ths info...... bro .. wt is the connector type for this phone????
1 X5?
Old 05-28-2008, 07:21   #3 (permalink)
Member: 310155
Thanks Meter: 1,313
i think conector is this type........................................
Old 05-28-2008, 07:25   #4 (permalink)
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
yes thats the Handfree points .... but i was talking about the bottom jack .... cozz i have done with one phone with pinfinder....through bottom connector..
Old 05-28-2008, 11:49   #5 (permalink)
jhepoy_org's Avatar
Member: 247410
Thanks Meter: 161
I used this connector type "Speaker jack"....
Old 07-27-2008, 11:03   #6 (permalink)
alexmkdMAFIA's Avatar
Member: 212574
Sonork: 100.1580063
Thanks Meter: 63
how to make the cable
Old 07-27-2008, 11:12   #7 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
Old 07-27-2008, 21:43   #8 (permalink)
Member: 148515
Thanks Meter: 19,534
hello mr. suntysunty!
which cable? for which model?
Old 03-20-2009, 14:57   #9 (permalink)
Member: 612829
Thanks Meter: 15
thanks for nice job bro
<< ub team-help me out >> .::koolfriend4u::. Universalbox 6 01-20-2010 03:26
ChineseMiracle test pin outs paklink Infinity-Box 41 08-23-2008 21:10
help.. n95 8gb need pin out.. acay Chinese Models & Cloned Phones 0 08-22-2008 12:23
n95 china phone pin-out MARCO_LEI24 Infinity-Box 6 06-08-2008 12:55
N95 8gb Test Point? How? Knowledge Nokia Base Band 5 ( BB-5 ) 9 12-03-2007 23:04
Page generated in 0.19700 seconds with 10 queries
