GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   N95 after Formatting also shuts OFF with sim... (https://forum.gsmhosting.com/vbb/f296/n95-after-formatting-also-shuts-off-sim-491387/)
harim_1981 01-17-2008 13:49
sir,
N95 after formatting the phone also it shuts off with sim'
without sim it remains ON..
log is here
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
chip: 0031:3184:F3E9
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.ABA3C7A8.[E553_XZY1ARVTFPA_E553_GPRS_MT6226_S01.01_1.BIN_6CE CA7A4].rpl
New firmware detected:
- make "Repair security area" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: ABA3C7A8
identification#1 protocol ver: 04
ver. sw1: E553_XZY1ARVTFPA_E553_GPRS_MT6226_S01.01_1.BIN
ver. sw2: E553_XZY1ARVTFPA.01.1
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00E00000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [eeprom[E553_XZY1ARVTFPA_E553_GPRS_MT6226_S01.01_1.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E553_XZY1ARVTFPA_E553_GPRS_MT6226_S01.01_1.BIN]_20080117-181305.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _ABA3C7A8_E553_XZY1ARVTFPA_E553_GPRS_MT6226_S01.01 _1.BIN_6CECA7A4_20080117-181437.B0X.bin
Finished, time used: 164 sec
Remove/Install battery now !
next what i have to do...
it says New firmware ....?
zakryia 01-17-2008 13:54
brother try with full format
InfinityHelp 01-17-2008 14:11
hello!
yes, you can try full format.
also worth to try: without sim call to 112. if phone shuts down- there is problem with power amplifier (PA IC)
also:
harim_1981 01-17-2008 14:40
thanks sir...
if i call 112 sets OFF...
so i think it is hardware faulty...
thanks sir...
InfinityHelp 01-17-2008 14:51
hello!
yes, looks like RF part hardware error
Page generated in 0.09790 seconds with 6 queries
