12-23-2007, 16:36 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: IN INDIA
Member: 263005 Status: Offline Thanks Meter: 147 | N95 big pls hlp mee |
12-23-2007, 20:57 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Select any "Chinese" model. Cable: Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts), bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
12-24-2007, 08:09 | #7 (permalink) |
Member: 263005 Status: Offline Thanks Meter: 147 | thanks infinity i will find that is N 95 PDA yours infinity have the pinouts in chineese miracle thankss a lot it will worked and fix the problem pin is 1: Gnd 2: Gnd 7: Rx 9: Tx |
01-05-2008, 18:37 | #8 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | Quote:
COM1 [Serial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 22 sec Remove/Install battery now ! My question: Do i have to completely remove usb connector when connecting on pcb: | |
pls hlp mee | alimuamin | Motorola P2k | 2 | 06-28-2008 12:46 |
my 300c urgnt pls hlp mee | alimuamin | SAGEM JTAG UNLOCKER | 1 | 05-24-2008 12:26 |
I am a new pls hlp mee guys | alimuamin | FuriousGold | 3 | 04-12-2008 05:44 |
SP CURRUPTED pls hlp mee very urgent plsssssssss | alimuamin | Nokia Base Band 5 ( BB-5 ) | 3 | 10-30-2007 16:28 |
