07-03-2009, 07:54 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | n95 china after flash white lcd use flash file from suport area after flash phone working bbut lcd is the white what is solutions COM4 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:6603:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.BIN ver. sw 2: MAUI.GEMINI.W08.12, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 38 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to delchoni For This Useful Post: |
07-03-2009, 09:08 | #3 (permalink) |
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | thanks for support now lcd is okk but phone send file wia bluetoth but cant recivied data from other phone phone set write file failed |
10-22-2009, 09:34 | #5 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Roumania
Member: 461923 Status: Offline Thanks Meter: 2,020 | hello..i have one n95_8gb with white screen.. ..please anybody can tell me which file is good for my phone ?? n95_8gb Type : RH-84 IC:661Z-RM159 code 0539266 CPU : MT6226BA ..this is PCB : |
The Following User Says Thank You to stefani For This Useful Post: |
10-23-2009, 07:18 | #7 (permalink) | |
Member: 461923 Status: Offline Thanks Meter: 2,020 | Quote:
module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:0B41:6C3C high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.7DFA6BDB.[N95_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_F2.BIN_5 7250030].rpl identification#1 detection finished device-id: 7DFA6BDB identification#1 protocol ver: 04 ver. sw 1: N95_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_F2.BIN ver. sw 2: MAUI.05C.W06.16.F2, CFFFDAA8 ffs offset/size: 00D00000/00300000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00D00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00D00000 detecting eeprom/ffs size... eeprom/ffs size: 00300000 ffs chip: 00 eeprom/ffs area: 00000000:00D00000-00FFFFFF detecting ffs structure pass 1... .................. detect standard fat location pass #1... .................................................. .. detect extended fat location pass #1... .................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok: element #1 detecting ffs structure pass 2... .................. detect standard fat location pass #1... .................................................. .. detect extended fat location pass #1... .................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_7DFA6BDB_N95_PCB01_GPRS_MT6226_S01.MAUI_ 05C_W06_16_F2.BIN_57250030_20091023-085928.B0X.bin Finished, time used: 255 sec Remove/Install battery now ! | |
10-23-2009, 23:18 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! we have 8 flash files on support. worth to try them. each time power On phone and check if this helped or not support area search example: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 |
11-06-2009, 09:24 | #10 (permalink) | |
..but all ok after write flash saved from a good phone.. ..this is flash...maybe help somebody.. http://rapidshare.com/files/30308588...94636.B0M.html | |
11-08-2009, 20:24 | #11 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
i will upload this firmware to our support site, keeping EEPROM area | |
chaina nokia 1650 after flashing white lcd plz help | guljee786 | Chinese Models & Cloned Phones | 4 | 08-16-2009 16:40 |
nokia 6300 china after flash white screen | sjni | Infinity-Box | 1 | 07-05-2009 20:31 |
N95-8gb China after flashing no Display | topnoyze | Infinity-Box | 4 | 10-07-2008 20:55 |
