n95 china charging only! Hi... can anyone help me with my problem in N95 china phone. The unit shows charging when charger is inserted but when i switch on... it turned off. Action taken: 1. check the switch... It's good 100% 2. flash it with infinity here is the logs: COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:93C1:86D6 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B9FEE332.[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1113A .BIN_6B42A100].rpl identification#1 detection finished device-id: B9FEE332 identification#1 protocol ver: 04 ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1113A .BIN ver. sw2: B10_EFATRIS_V1113A, FF5EBD94 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1113A .BIN]]... warning: wrong cs at 0x00444C00, retry... read error recovered warning: wrong cs at 0x00575000, retry... read error recovered warning: wrong cs at 0x005BFC00, retry... read error recovered warning: wrong data size at 0x00CFF400, retry... read error recovered file saved: C:\Program Files\InfinityBox\ChineseMiracle\LBC client n95\backup_flash[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1113A .BIN]_20080523-184808.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _B9FEE332_T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAT RIS_V1113A.BIN_6B42A100_20080523-184828.B0X.bin Finished, time used: 1626 sec Remove/Install battery now ! COM4 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:93C1:86D6 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 95 sec Remove/Install battery now ! Please help... Thanks! |
BTW.. I tried to find these flash files in support area but "no files found". |
hello! we dont have exactly same version, but you can make search for "T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS" and try similar files |
Thank you so much for the quick reply. I'm gonna download it right now.:) |
SUCESS!!! Thank you so much Infinity Help. I used a similar flashfile in the support area. After writing a firmware for the second time, I finally made it! :D COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:93C1:86D6 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B9FEE332.[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1105A .BIN_6E553A4E].rpl identification#1 detection finished device-id: B9FEE332 identification#1 protocol ver: 04 ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1105A .BIN ver. sw2: B10_EFATRIS_V1105A, B1C5AA91 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1105A .BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\LBC client n95\backup_eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1105A .BIN]_20080523-221759.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22202200:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _B9FEE332_T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAT RIS_V1105A.BIN_6E553A4E_20080523-221828.B0X.bin Finished, time used: 270 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! http://i140.photobucket.com/albums/r...3052008128.jpg |
Hi! I have a problem downloading the same file that you use from the support site because I have a problem with my registration. Can you share me your flash file and eeprom file if you still have it? thanks! |
