11-12-2007, 11:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: romania Age: 48
Member: 48215 Status: Offline Thanks Meter: 19 | j120 after unlock unautorized phone with all network when try repair eeprom COM5 [VCP0] selected Device: Sony-Ericsson J120i "advanced chip detection" active Action: repair Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208814FFFFFFFF:20881400000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: MLD-5- Check flash Done Check parameters... reading Sony-Ericsson J120i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J120i_eeprom_calibration-1_20071112-122344.6AE.bin Check parameters Done Check data... Check data Done Writing... ....error: required data not found or unknown eeprom structure Writing Fail Finished, time used: 22 sec Remove/Install battery now ! when try to write eeprom COM5 [VCP0] selected Device: Sony-Ericsson J120i "advanced chip detection" active Action: flash write "smart write" active Skip: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208814FFFFFFFF:20881400000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: MLD-5- Check flash Done Check parameters... reading Sony-Ericsson J120i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J120i_eeprom_calibration-1_20071112-122530.6AE.bin Check parameters Done Check data... Check data Done Writing... Area: Eeprom flash: 208814FFFFFFFF:20881400000000 Write: Eeprom error: error# 000000B2 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 02:1[01]: Block locked during program or erase; operation aborted. error: flash write error: 003F0000:00002000 Writing Fail Finished, time used: 188 sec Remove/Install battery now ! Now the phone dont accept any card What can do? |
11-12-2007, 11:44 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. You must use LATEST (this meand not old) software from support area: download it NOW 2. restore original eeprom (backup was automatically created) 3. make unlock |
11-12-2007, 15:14 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Uf... again 25... SE J110i/J120i unlock and repair supported by Infinity-Box. All software versions supported. All operators supported. Dead phones repair supported. "Unauthorized" phones repair supported. More info here: http:///vbb/showthread.php?t=454234 |
11-12-2007, 22:34 | #7 (permalink) |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | Successfully repaireed Unauthorized J120 phone after flash repair eproom and ffs from support erea then hit repair boutton to finish job, please c repair log details below: COM10 [VCP1] selected Device: Sony-Ericsson J120i "advanced chip detection" active Action: repair Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 032H-000 version sw: MLD-5- Check flash Done Check parameters... reading Sony-Ericsson J120i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J120i_eeprom_calibration-1_20071112-212747.6AE.bin Check parameters Done Check data... Check data Done Writing... .........data prepared Ok flash: 89886200010001:89886200000000 Write: eeprom Writing Done Finished, time used: 39 sec Remove/Install battery now ! |
After unlocking done, phone is locked to all networks | emedli | Sony Ericsson | 5 | 08-15-2008 14:22 |
[03.06.2008] ALL LG Phones Unlock by IMEI (WorldWide all Networks Supported) | AtrixJ | Main Sales Section | 0 | 06-03-2008 13:59 |
K800 wont work with o2 pay and go sim after unlock but work with all other sims | anks | KULANKENDI Server | 3 | 09-21-2007 23:26 |
